Iat Sensor - BMW Forum - BimmerWerkz.com
Old 06-09-2005, 09:03 PM   #1 (permalink)
flemishlion is an unknown quantity at this point
Hi all,
I just want to have a slight increase in the HP of my 325 cic. What seemed to me the best (and real cheap) solution is an iat sensor modification.
My questions to the list:
1. is it safe for the engine, and can it void the warranty?
2. has anybody experience with this kind of modification, and are there 'better' or more reliable brands?
Thanks,
flemishlion is offline   Reply With Quote
Old 06-10-2005, 04:19 AM   #2 (permalink)
alanh's Avatar
alanh is an unknown quantity at this point
Send a message via AIM to alanh
first, not even sure our cars have that
second i thought that only delt with cold start up performance,
and ive never heard of anyone doing that on a bmw
pretty sure that'll void your warenty
there arne't really any "cheap" ways to get much power from these car, but you might want to start with software
Self-Proclaimed Genius
alanh is offline   Reply With Quote
Old 06-10-2005, 06:44 AM   #3 (permalink)
Pete is an unknown quantity at this point
flemishlion, are you talking about the intake air temperature sensor? Although I have not heard of this as a performance boost possibility I am open to anything new. The sensor info (from another website) is:
"The IAT1 Intake Air Temperature sensor is often used to replace the stock IAT sensor when MAF (Mass Air Flow) kits are installed. On many air flow meter (AFM) cars, the IAT sensor is internal to the AFM. When the AFM is replaced by the MAF sensor, the stock IAT sensor is removed. The IAT1 replaces the stock IAT sensor and can improve cold start performance. It is generally installed in the stock air box in front of the air filter. The IAT1 comes with a connector and nut to hold it in place"
As this is generic information, I am unsure if it applies to BMW but if you have more info. please let us know.
Pete is offline   Reply With Quote
Old 06-10-2005, 07:10 AM   #4 (permalink)
i think what he is talking about is relocation.
in stock 325/330 this thing is near maf, and close to manifolds. so it heats up, and thinks the incoming air is hot. so it then retards the ignition, and makes less fuel squirt out.
if you lenghten the wires, and mount the sensor as distal as possible from the engine heat, it measures the correct temp. i think anytime you buy throttle bodies from dinan, this mod comes automatically.
no need to remap software.
Old 06-12-2005, 08:50 PM   #5 (permalink)
Sorry, I was not clear .
Take a look at this link, and if somebody can tell me if this is bogus or real (and yes , I really don't know much about engines, I just like to drive)
http://www.hurricane-horsepower.com
Thanks
Old 06-13-2005, 06:06 AM   #6 (permalink)
i woudl not touch it with a ten foot pole.
too much ignition advance and you get detonation.....
Old 06-13-2005, 11:59 AM   #7 (permalink)
I am with you peterkuleza, there is no way that I would put this on my car.
I wonder why you want "a slight increase in HP"? A slight increase is really not cost effective. BMW has already squeezed the majority of the power out of it's 325ci engine, any more will come at a significant cost.
Check Engine Light came on today camnipotent 3-Series (E36) 22 05-17-2004 06:23 PM
New Car - Few Problems, Any Help Appreciated. Sagan 3-Series (E36) 8 05-16-2004 09:28 PM
O2 sensor rawcar2long 3-Series (E36) 2 01-22-2004 10:56 AM
ABS sensor light fault.. Ski Bimmer Talk/Motorsports Talk 6 04-18-2003 08:38 PM
