i think i screwed up my tranny - BMW Forum - BimmerWerkz.com
Old 01-22-2010, 11:14 PM   #1 (permalink)
oldman is on a distinguished road
Hello there new member and bmw owner. I just changed the tranny fluid in my 2005 bmw 325i. 5 speed tranny. i found out later that you don't need to change it for some reason. i put royal purpple high perfomence tranny fluid in. now in 1st through 3rd gear it makes a whineing sound. doe's anyone know if i put the wrong stuff in and what should i do about it. can anyone out there please help me
oldman is offline   Reply With Quote
Old 01-22-2010, 11:17 PM   #2 (permalink)
Well to start, the whole no changing the transmission fluid myth is just that. How many miles are on the gear box?
Old 01-22-2010, 11:38 PM   #3 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
5 speed auto or manual? Auto trans requires 8 liters of ATF fluid, not sure on the manual.......though
Found this info on manual trans fluid @ bavauto.com
http://www.bavauto.com/se1.asp?dept_id=318
Please check your vehicle for the proper fluid requirements. Transmission will be labeled with the proper fluid. This fluid replaces MTF-LT1 and MTF-LT2 BMW original fluids. Please fill or top off with the proper fluid only. Please note: For Vehicles With Either Yellow Or Blue Label On Transmission
jb
Old 01-23-2010, 12:23 AM   #4 (permalink)
its a manual 5 speed trans. has 71500 + or - a few.
Old 01-23-2010, 12:28 AM   #5 (permalink)
the trans reservoir cap says atf only so im a little confussed.
Old 01-23-2010, 02:56 AM   #6 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Your confused....a manual box does not take ATF (Automatic Transmission Fluid)
Old 01-23-2010, 03:30 AM   #7 (permalink)
marti5's Avatar
From the diagram in the link the fill and drain plugs are on the box #5, normally only auto boxes have a reservoir and most BMW's dont have a res and have to be serviced via the fill/drain plugs, I would think you are filling the power steering....
RealOEM.com BMW E90 325i GS6-17BG seals/mounting parts
Old 01-23-2010, 03:45 AM   #8 (permalink)
i didnt fill the power steering res. i filled it through the dip stick tube. any reason why its making the whineing noise.
Old 01-23-2010, 03:50 AM   #9 (permalink)
marti5's Avatar
Fluid level to low, I will do some more investigation as I didnt know they had a gearbox dipstick....
You may have the wrong fluid in:
From model year 2004 some manual transmissions are filled with Castrol “MTF-LT-2” lifetime fluid. This fluid has the
same properties as the “MTF-LT-1”
The “MTF-LT-1” fluid may be mixed and/or
substituted for the “MTF-LT-2” manual transmission fluid.
Old 01-23-2010, 11:57 AM   #10 (permalink)
Marti is correct, there is no dipstick tube for either manual or automatic trans.......the engine dipstick is red & many people mistaken this as the transmission
filler tube.....If you drained your fluid from the trans, & filled the red dip stick filler with Royal Purple, then you just added Royal Purple to your engine, if you added it to the black star shaped round cap, then you added it to your power steering system.......& your trans is making noise, because it is running dry!
This is the procedure for manual trans fluid change:
M 3 . M A D R U S S I A N . N E T
This is the procedure for AUTO trans fluid change:
Best Way - DIY E46 Transmission Filter Change | eHow.com
Red stick-Engine Oil
Black Star shaped Round Cap-Power Steering Fluid
Old 01-23-2010, 02:08 PM   #11 (permalink)
marti5's Avatar
JB, thanks for the conformation, I thought I was going mad for a minute as I'm really a 7 series man, but know quite a lot about all models and thanks for you link inpost re: manual box fill above which confirms my post#7...cheers.
oldman....you have been running your box with no fluid.....!!, you need to follow instrutions in JB's link if it whines after that youve done damage, if no whine youve taken minimum 10-20k off its life....
Old 01-23-2010, 09:00 PM   #12 (permalink)
Cheers Marti, well deserved!
jb
Old 01-24-2010, 11:23 AM   #13 (permalink)
thank you gentleman for all your help. it has stoped whining and still shifts smooth. one more thing since i put trans fulid in the enginewill it mess it up. i alresdy changed it.
Old 01-24-2010, 11:48 AM   #14 (permalink)
You are welcome, It won't mess up your engine as long as you drained the oil out while the engine was warmed up.......to thin it out, so it drains well!
jb
I Screwed Up, Need Help JWK Wash & Detail 3 08-08-2005 05:19 PM
Im Screwed Help Me. zeidakiss 3-Series (E36) 4 07-27-2005 08:28 AM
Some Help Me So I Dont Get Screwed CityFracture 3-Series (E36) 10 11-12-2004 01:39 AM
Am I getting screwed or what? Voidy 5-Series (E12,E28, E34, E39, E60) 3 12-07-2003 05:49 PM
