I Still Got The Problem (new Engine?) - BMW Forum - BimmerWerkz.com
Old 04-05-2005, 06:18 PM   #1 (permalink)
rossie150 is an unknown quantity at this point
323ci
2 vanos units
1 vanos breather hose
1 set of spark plugs
1 camshaft position sensor
1 ecu
1 set of coil packs
checked injectors
and i still have a low rev misfire when hot
today it sounded like it was running on 3/4/5 cylinders (bub bub bub) the first time this has happened !
i have taken the car to woods,coopers and now hampshire cars the guys there say they are out of ideas and have contacted bmw gb, i have also been booked in for a week next week. is a new engine on the cards or will i get somthing else?
what should i do?
rossie150 is offline   Reply With Quote
Old 04-06-2005, 11:03 AM   #2 (permalink)
storme's Avatar
storme is an unknown quantity at this point
HEY U LIVE NEAR ME
just a thought,,,,maybe it is running tooooo hot,,,and you are getting heat soak???
i know you probably have the original air filter etc
but mine was running too hot,,,and had this affect....
i changed to the correct spark plugs,,,car ran cooler and no misfire,,all because of heat soak...so said woods of bmth
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Old 04-06-2005, 11:34 AM   #3 (permalink)
well i must admit 'heat soak' is new to me, the thing is they already changed the spark plugs and there was no improvment
when you say you had the wrong spark plugs ,where they fitted at bmw?
temp seems fine never more than halfway
Old 04-06-2005, 12:23 PM   #4 (permalink)
storme's Avatar
heat soak being the heating of the air that goes into the engine,,,not the temperature of the water and/or oil.
if the temperature of the air is too hot it will fuel badly,,,,,hence on a cold day,,your car goes like the clappers...and on a warm day,,,if dont feel the same...
its just a thought,,,could well be miles wrong
Old 04-06-2005, 12:26 PM   #5 (permalink)
///Matt's Avatar
This may be a long shot, but it sounds like a vacuum leak (especially if the cyliners are next to eachother) Intake manifold gasket failure?
Old 04-06-2005, 12:59 PM   #6 (permalink)
when i say 3/4/5 cylinders i probably mean 5 i would usualy say 3 but its got six????
vacuum leak only when hot?
Old 04-06-2005, 09:08 PM   #7 (permalink)
although it is not really common it IS possible for a only hot vacume leak. if the gaskets are just on the verge of failure when they get hot they expand and could create a leak. next time it's in it might be worth mentioning to the tech. did they ever say what kind of faults were storred in the computer?
Old 04-07-2005, 01:38 AM   #8 (permalink)
apperently there are no faults hence contacting bmw gb for advice
could having this problem over a period of say 4-5 months done any permanent damaged to my engine?
it dosent sound very nice at low revs like it did
Old 04-07-2005, 08:33 AM   #9 (permalink)
if it has been over 4-5 months i would dobt that it is a vacume leak becasue usually something like that will get worse as time goes on. as far as damage goes it shouldn't do any permanent damgae. the only thing you might have to worry about are the spark plugs getting fouled becasue it is misfiring
Old 04-08-2005, 12:59 PM   #10 (permalink)
rsn48 is an unknown quantity at this point
Could also be a fuel filter problem (cheap fix) or your fuel pump.
rsn48 is offline   Reply With Quote
Old 04-08-2005, 03:01 PM   #11 (permalink)
i took it for a long drive today and then after about 1/2 hr it seemed to lose power and run on five constanly for about 2 miles then i swiched it on and off and it was fine (ish) ???
Old 04-08-2005, 03:58 PM   #12 (permalink)
storme's Avatar
next time it does this,,,,undo the fuel cap...then drive off and see if there is a difference
Old 04-08-2005, 05:47 PM   #13 (permalink)
will do
Synthetic Oil and filter CiscoKid 3-Series (E36) 45 04-25-2007 10:50 PM
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-10-2006 11:56 PM
645 Engine Problem? Rick24m 1,6,7,8 - Series and Mini Cooper 1 03-25-2005 01:25 PM
engine problem bambam669 5-Series (E12,E28, E34, E39, E60) 7 09-09-2004 07:49 PM
