How to take turn signal cover off - BMW Forum - BimmerWerkz.com
Old 08-25-2004, 03:02 PM   #1 (permalink)
wakko is an unknown quantity at this point
Would someone please tell me what I am missing when I try to take the right front turn signal cover off? I need to change out the light bulb, but can't take the cover off! The manual looks easy, but it isn't so. Thanks
wakko is offline   Reply With Quote
Old 08-25-2004, 04:55 PM   #2 (permalink)
EnvyM3's Avatar
EnvyM3 is an unknown quantity at this point
Send a message via Yahoo to EnvyM3
If it is the corner marker, there is a slot in the metal fender (a little hole in the part where the bolts of the fender are attached). Just stick a screwdriver in that hole and push down the clip that is attached to the light, followed by a little tug on the corner marker and it should pop right out. If it is the side marker, slide the side marker forward (should move about a centimeter) and pry the back end of it up and it pops right out. Hope that helps. Good luck!
<img src='http://www.european-forums.com/forums/uploads/post-1-1119565837.jpg' border='0' alt='user posted image' />
EnvyM3 is offline   Reply With Quote
Old 08-26-2004, 12:44 AM   #3 (permalink)
alpinestar's Avatar
alpinestar is an unknown quantity at this point
Take a small flashlight and shine that beam in the hole! U can see the a little plastic tab which you need to push down on with a screwdriver while simultaneously pulling the light assembly forward.
alpinestar is offline   Reply With Quote
Turn Signal Problem, stuck on, not blinking. jek1955 3-Series (E36) 2 10-27-2005 06:48 AM
Turn Signal Issues Help warell 3-Series (E46, E90) 4 01-20-2005 02:57 PM
1984 528e Turn Signal Questions. rock_martyr 5-Series (E12,E28, E34, E39, E60) 1 11-09-2004 11:47 PM
Turn Signal Regulator eclypser 3-Series (E36) 1 09-04-2003 02:30 PM
97 328i Turn Signal Relay dhruvm 3-Series (E36) 0 09-02-2003 04:18 PM
