Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 06-06-2006, 07:50 AM   #1 (permalink)
Photos: 0
khanjee75 is on a distinguished road
How to replace Final Stage Resistor
Hi Guys,
Can any body tell me or direct me to the step-by-step instructions on how to replace the final stage resistor. I have got 2000 BMW 325i SE.
Thanks in advance,
KhanJee
khanjee75 is offline   Reply With Quote
Old 06-06-2006, 06:57 PM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Photos: 0
Remove the plastic cover behind the glove box (passenger side) look toward the drivers side close to the bulkhead and it will be there, disconnect the plug, release the clip and pull back gentally (don't break the clips!) it's pretty easy.
Come see me at MySpace
Old 06-14-2006, 01:52 PM   #3 (permalink)
Photos: 0
Kulbiker is on a distinguished road
Any pics to go with that or a website that shows how? Greatly appreciated....my blower is driving me nuts and I need to get the thing sorted out....I am guessing from most posts its the final stage resistor since the only problem I am having is that the climate control has a mind of its own. Rest everything works hunky dory when that is it comes on. The A/C cools, the heater works...etc etc.
Oh and Khanjee where did you buy the final stage resistor from....? Any info will be appreciated.:
01 325 xi E46 Bimmer Titanium.....FAST
99 600cc Suzuki GSX-R Blue..........FASTER
My stupid temper.......FASTEST
Kulbiker is offline   Reply With Quote
Old 07-01-2007, 02:34 AM   #4 (permalink)
Car: 2001 325i SE
Photos: 0
MJRyan9 is on a distinguished road
E46 Final Stage Unit
I experienced the same symptoms (blower running at one speed) on my 2001 325i. Searching the web I found an off-beat article about Resetting the FSU:
http://www.refrigerants.dupont.com/S...acs_200506.pdf
See page 5: The Final Stage. I know - hard to believe finding BMW advice from a dupont website, but I tried this (pull Fuse 50 and replace) and it worked! . Apparently the FSU is an electronic speed controller and is powered even when the key is Off; so you need to pull the fuse to reset. A lot less time and $.
As the FSU design is probably similar on other models one might try pulling/replacing the appropriate blower fuse on non-E46s: refer to the fuse list by the fuse panel.
Best of luck,
Mike
MJRyan9 is offline   Reply With Quote
vB code is On
Maitenence Checklist- The Full Monty mmzcee 3-Series (E36) 12 12-05-2004 06:43 AM
Final Stage Replacement speaknspell 5-Series (E12,E28, E34, E39, E60) 1 07-28-2004 10:13 PM
Help Final Stage Blower tshegos 3-Series (E36) 2 07-21-2004 11:40 AM
Fan/Blower Unit failure - final Stage Resistor? badaxe 3-Series (E36) 0 07-16-2004 04:56 PM
final stage resistor fly gti 5-Series (E12,E28, E34, E39, E60) 2 06-23-2004 09:30 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
