How to remove REAR WINDOW SHELF - BMW Forum - BimmerWerkz.com
Old 11-21-2005, 03:21 AM   #1 (permalink)
vinchung is on a distinguished road
Hi all
Can anyone gives me some ideas on the steps to remove the REAR WINDOW SHELF.
Many thanks
Vincent
vinchung is offline   Reply With Quote
Old 11-21-2005, 11:30 PM   #2 (permalink)
BMWERKEN's Avatar
BMWERKEN is on a distinguished road
Send a message via AIM to BMWERKEN
1) Pull up the rear head rests.
2) Pull down the top part of the rear seats, you just pull them.
3) Remove the rivets that hold the rear deck to the top part of the rear seats (they are plastic black rivets).
4) Remove the side panels and reading lights. The reading lights come out by wedging a screw driver in the side and twisting carefully. You can then just pry the side panels out.
You should now be able to pull the rear deck towards the front of the car.
Call Toll Free: 1.888.JLEVISW
PREDATOR ICE OEM ANGEL EYE UPGRADE | PREDATOR CHROMIUM ANGEL EYES | LED TURN SIGNALS
BMWERKEN is offline   Reply With Quote
Old 11-23-2005, 08:28 AM   #3 (permalink)
thanks for the detail steps, i'll try it in the weekend.
just one more question, what holds the vertical part of the rear seat in place, the head rests or any clips or rivets ??
thanks again
cheers
Old 11-29-2005, 04:19 PM   #4 (permalink)
BMWERKEN's Avatar
You will need to pull up the headrests to remove the rear deck but the vertical part is held in by two huge clips. Just pull on the top of the backing of the seats and they will pop right out
Old 12-04-2005, 09:42 AM   #5 (permalink)
Talking
got it, many thanks!!
Old 12-05-2005, 08:12 AM   #6 (permalink)
exjarhead328's Avatar
exjarhead328 is an unknown quantity at this point
BMWERKEN, you've piqued my intrest. I get terrible radio reception, especially AM. I've seen some posts in the past that say it could be a bad antenna amplifier and the writer mentions it being located in the rear pillar, I believe driver side. Could this be accessed by removing the side panel?
SEMPER FI 2/3 Comm
Founder of the Four Pedal Club
2000 328
exjarhead328 is offline   Reply With Quote
Old 12-13-2005, 09:14 AM   #7 (permalink)
i came across this photo showing the left rear pillar which may be able to answer your query.
http://e46.mit.edu/Originals/BMW_OEM...t/IMG_0102.JPG
web site
http://e46.mit.edu/BMW_OEM_Widescreen_NAV_Retrofit.htm
735 1998, rear window roller blinds phil 1,6,7,8 - Series and Mini Cooper 3 02-08-2011 05:02 AM
used 528: rear window & cam belt question jcmky 5-Series (E12,E28, E34, E39, E60) 1 10-16-2005 04:37 PM
Rear Window Defroster (325i) Not Quite Right? lessthanzero 3-Series (E46, E90) 2 02-16-2005 05:10 AM
Very Hot Spot On Wagon/touring Rear Window nv325xiT 3-Series (E46, E90) 2 01-25-2005 03:16 AM
Rear power window failure Minardi 5-Series (E12,E28, E34, E39, E60) 2 08-14-2004 01:23 AM
