How To Lift A 325i With Floor Jack - BMW Forum - BimmerWerkz.com
Old 04-11-2005, 01:24 AM   #1 (permalink)
recycle_bean is an unknown quantity at this point
I want to change the tires of a 325i, and I have a 2-ton floor jack. How do I lift the car? Any tips? The problem is.. there are 4 rubber thing (see link below) which I think it fits the factory scissor jack. If I put the floor jack under that, will that damage the thing? or I need to get something in between to fit into that rectangle?
http://www.bmw325i.net/images/rear_c...d/IMG_8804.jpg
help...
recycle_bean is offline   Reply With Quote
Old 04-11-2005, 10:08 AM   #2 (permalink)
jeremer is an unknown quantity at this point
help...
[snapback]329945[/snapback]
Just add a piece of 2x4 wood between the rubber and the floor jack, make sure you hand braked the car.
jeremer is offline   Reply With Quote
Old 04-12-2005, 01:17 PM   #3 (permalink)
The thing in the picture are the jacking blocks and will take e trolley jack as long as the dish of the lift plate doesn't hit the sill you'll be OK
Old 04-12-2005, 04:05 PM   #4 (permalink)
Thanks.. Does that mean that the whole rubber thing is made of steels? If so, I can just put my floor jack under on the recentagle rubber thing. I just want to confirm, not wanna do any damage. :P
or do I have to get something fit in the CENTER of the rubber like what this guy did? http://www.bmw325i.net/raise_front.shtml
Please advice..
Old 04-13-2005, 09:33 AM   #5 (permalink)
CiscoKid's Avatar
you can jusr lift on the rubber pad
VIN check please E30 giz Bimmer Talk/Motorsports Talk 6 07-28-2004 06:02 PM
