How to execute "engine brake" properly? - BMW Forum - BimmerWerkz.com
Old 01-16-2009, 02:35 PM   #1 (permalink)
Superbug is on a distinguished road
Bought a 2006 325i about 3 months ago, it was my first manual and I had never driven manual before that. I use so called "engine brake" intermittently, both under highway and local traffic speeds. What I do is after I shift to a lower gear, I slowly ease out the cluth and let input and output shaft sync up without so called "rev match". This is the proper way of performing an engine brake or I am going to wear out transmission prematurely? Thanks a lot.
Superbug is offline   Reply With Quote
Old 01-16-2009, 02:57 PM   #2 (permalink)
You should blip the throttle to make the engine match the revs. The way you're doing it will wear on the transmission synchronizers (they are doing the rev match for you).
Old 01-16-2009, 03:00 PM   #3 (permalink)
Thanks a lot.
Old 01-16-2009, 03:24 PM   #4 (permalink)
Nick_318is's Avatar
Car: 1991 318is, 2005 Subaru Legacy GT
Nick_318is is on a distinguished road
Send a message via AIM to Nick_318is
Yeah you need to blip the throttle to rev match on the downshift, you will get a smoother shift as a result (no jerking).
Originally Posted by yammahamma View Post
If I wanted to date you, I would have bought you dinner first.
Nick_318is is offline   Reply With Quote
Old 01-16-2009, 03:44 PM   #5 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Not only that, but a lot of the wear is on the clutch, too. Blip the throttle up to where it should be given the speed and gear, then ease out the clutch.
Lindsay fan club member.
Old 01-16-2009, 05:26 PM   #6 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
So here I come sounding like a broken record:
Blip the accelerator to rev match before letting off the clutch. You don't want to stress your clutch.
Furthermore, I usually rev match plenty of time ahead of when I need to slow down, and only after I have downshifted do I actually hit the brakes. You must be thinking, "but that isn't engine braking at all." You would be correct. I avoid engine braking, which places stress on the exhaust valves. I recommend all drivers of manuals do the same. I use my brakes to slow down -- not my engine.
Turkey Fleet Bond Holder
Old 01-17-2009, 12:04 AM   #7 (permalink)
O_O Can you explain the stress on the exhaust valves bit please?
Old 01-17-2009, 10:50 AM   #8 (permalink)
Nick_318is's Avatar
+1 DRZ, the brakes are for slowing down not the engine!
Old 01-28-2009, 12:19 PM   #9 (permalink)
what's the sequence for a proper enginine brake? I found it not very effective to rev up the engine in order to slow down a car quickly, since the car is basically told to accelerate while the intention is to slow down.
Old 01-29-2009, 07:33 AM   #10 (permalink)
Teh Prof's Avatar
If you want to slow down your car quickly, then use traditional brakes. Engine braking is not meant to slow you down quickly--but it will slow you down.
Old 01-29-2009, 08:18 AM   #11 (permalink)
drz
drz's Avatar
Car: zhp
I agree.
E46 Abs, Dsc, "brake" Lights On ervinz 3-Series (E46, E90) 5 07-19-2011 01:03 PM
'02 530i False "Check Brake Linings" Msg Shiny Side Up 5-Series (E12,E28, E34, E39, E60) 7 09-25-2009 09:25 AM
"check brake light circuit" on bmw 325is mickey428 3-Series (E21, E30) 4 02-04-2009 09:13 PM
"brake Light Circuit" Message On Console GatorInSC 3-Series (E36) 6 10-29-2004 09:00 AM
