How do I fix the driver door creak/rattel? - BMW Forum - BimmerWerkz.com
post #1 of 9 (permalink) Old 09-13-2004, 08:46 PM Thread Starter
99_323i is an unknown quantity at this point
How do I fix the driver door creak/rattel, the driver door creaks going over bumps. Its a 1999 323i.
99_323i is offline
post #2 of 9 (permalink) Old 09-13-2004, 10:42 PM
jonshee92 is an unknown quantity at this point
man~ i feel ya...
I got a 2003 325i with only 17k miles and it's doing the same shit...
rattles all the time especially when the window is up...
let me know if you find anything out.
JOhn
jonshee92 is offline
post #3 of 9 (permalink) Old 09-14-2004, 12:32 AM
cptDean is an unknown quantity at this point
It's also happening on my 2002 325i. To me, it sounded like a low pitched "squeak" that goes away when I lower the windows. I let a friend drive it while I sat in the passenger seat (where the problem is worse) and I could make the sound stop if I put a LOT of pressure against the top of the window.
I'm going to try and lube the top of the window, but I'm not sure what to use. Please let me know if you guys figure out something that works. It really is annoying.
-Dean
cptDean is offline
post #4 of 9 (permalink) Old 09-14-2004, 12:52 AM
Im about to call the dealer and try to get if fixed under warranty. Paid almost 40k for this ~ so I expect a little more quality
post #5 of 9 (permalink) Old 09-23-2004, 01:02 AM
dudmahn is an unknown quantity at this point
I am in the process of purchasing a 2001 325i that has precisely the same problem. There is a squeak/crackling noise coming from the top of all four windows when accelerating, braking, and going over bumps. Rolling down the windows very slightly to relieve the pressure seems to eliminate most of the squeaking.
I had the dealer service dept. lube the window seals, and the problem is still there. The mechanic said it may have something to do with the window guides, and not just the seals, but he wasn't quite sure. He said that they may need to tear the doors apart to figure it out. Sounds VERY expensive!
Someone (not the dealer mechanic) suggested that reducing the travel/force on the power window motors (if possible) might eliminate the noise. Does anyone know if this type of adjustment is possible?
I would be very interested in knowing if there is a solution. It seems from the posts here that this is a fairly common problem.
dudmahn is offline
post #6 of 9 (permalink) Old 09-23-2004, 01:40 AM
white 330ci is an unknown quantity at this point
ya i had the some thing on my drivers door, what happens is, there are bolts inside the door that will back out, you just have to get in their and tighten them, then put on some locktite to prevent it from happening again.
white 330ci is offline
post #7 of 9 (permalink) Old 09-23-2004, 09:46 AM
[snapback]197345[/snapback]
Thanks for the quick response!
Could you please provide more detail on the location of these bolts, and how to obtain access to them? I imagine that these bolts are probably located on the narrow part of the door, above the window somewhere, and they they hold the window guides in place? Is this a simple fix, or does it require removing trim, door panels, etc? used
dudmahn is offline
post #8 of 9 (permalink) Old 09-23-2004, 02:10 PM
they are behind the door panel, you have to take it off, i think it is held on by screws, the bently manual has the locations, for your car.
if you just get the door panel off, you should be able to see what bolts they are, or just look for the loose ones. :wink
post #9 of 9 (permalink) Old 09-24-2004, 07:27 PM
[snapback]197610[/snapback]
Thanks for the extra info. Instead of taking the door apart, I tried the suggestion (linked below) about lubing the door/A-pillar seal (not the window seal), and it fixed the problem completely!
http://www.bmw-forums.com/forum/index.php?...topic=15678&hl=
dudmahn is offline
my sunroof is not flush with roof,how should i fix that? träumer 3-Series (E21, E30) 0 11-01-2005 03:18 AM
Driver Side Door Lock Getting Stubborn ultraviolet353 3-Series (E36) 8 01-15-2005 08:37 PM
Audiophile Speakers...i Need A Front Driver. nerf26 5-Series (E12,E28, E34, E39, E60) 0 10-08-2004 02:28 PM
Sunroof Opening Delay And Driver Window Opening St ginner 3-Series (E36) 1 10-04-2004 05:52 PM
Driver Side Window Won't Seal bren 3-Series (E36) 3 07-07-2004 12:13 PM
