Help w/ Sunroof tracking - BMW Forum - BimmerWerkz.com
Old 01-27-2004, 02:02 AM   #1 (permalink)
Nosic is an unknown quantity at this point
I was messing w/ my sunroof and held the moonroof open button for too long ~20 seconds inorder to set the end point and now it has lost its one touch feature. In order to close it I have to hit the close button about 4 times. I also have a question regarding my air. Every time i turn the car on, the blower comes on at its lowest setting, even when the car is turned off w/ the air off. But if i turn the car off w/ the blower @ a different setting, when i turn the car back on, the blower will start @ that medium setting or so. I also want to know where the outside temp. setting is located, because my temp hasn't changed from -40, regardless of the outside temp. I want to know if i should replace it, or does it have to do w/ the software? Please help... Thanx
Nosic is offline   Reply With Quote
Old 01-27-2004, 06:32 PM   #2 (permalink)
TECH's Avatar
Move the sunroof to the up tilt position. Hold the button for about 10 seconds are so, and it will tilt up a bit more. That is how you initialize that sunroof. There are no end point learnings for you to do.
I think the ac fan thing you mentioned is normal.
The ambient temp sensor is on the front left fender corner trim, under the fog light. If it's reading -40, it's probably been ripped off......
Old 01-28-2004, 08:27 AM   #3 (permalink)
Fangs's Avatar
Fangs will become famous soon enoughFangs will become famous soon enough
I always wondered where the Temp sensor was... Thanks
<span style='font-size:12pt;line-height:100%'><span style='color:blue'>I don't drive fast,</span> <span style='color:red'>I FLY LOW</span></span>
'99 323i
'02 540i
Fangs is offline   Reply With Quote
Roof Rattles A Bit. Sunroof Issue? ynotony 3-Series (E36) 4 07-18-2005 09:41 PM
Sunroof Issue bmwfool 3-Series (E36) 4 05-18-2005 12:42 AM
My Sunroof..... breezd 3-Series (E36) 4 04-15-2005 10:03 PM
Sunroof Noises Caused By Vibration. victorgallas 3-Series (E36) 0 01-20-2005 03:27 PM
sunroof problem? help!!! pherbolario 5-Series (E12,E28, E34, E39, E60) 4 12-30-2004 05:57 AM
