Help: Vehicle vibration from 20-27 mph - BMW Forum - BimmerWerkz.com
Old 08-19-2011, 07:48 PM   #1 (permalink)
psone is on a distinguished road
I have an '04 325i Sedan with 140k miles. For about 10 days the entire vehicle shakes/vibrates when accelerating in the range of 20mph to 27mph then stops. No vibrations before 20mph or after 27mph. Seems pretty violent, change in the center console makes noise.
Replaced the tires yesterday, took the vehicle for an alignment today, due to poor front bushings they couldn't do the alignment, but I will have those this weekend and take it back. Although they did say the vibration is not related to alignment.
So, the question is, what's the #1, #2, etc cause that I should try?
psone is offline   Reply With Quote
Old 08-20-2011, 07:01 AM   #2 (permalink)
jimmythepie's Avatar
Car: 98,328i
bushing
jimmythepie is offline   Reply With Quote
Old 08-20-2011, 02:10 PM   #3 (permalink)
Can you please elaborate?
Old 08-21-2011, 06:03 AM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Replace the suspension bushes... Best to do them all in one go !!
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 08-21-2011, 02:03 PM   #5 (permalink)
Car: 1989 - 2011
The German Guy is on a distinguished road
Hi there,
I'd also bet that you have to go for new control arm bushings... recommend to install Meyle HD!
Viele Grüsse!
The German Guy is offline   Reply With Quote
Old 08-21-2011, 07:01 PM   #6 (permalink)
Are there any guides that outline the process? I recently found out the control arm bushings are bad too, so those are getting replaced.
But, can't seem to find a DIY on replacing the suspension bushings
Old 08-22-2011, 07:55 AM   #7 (permalink)
Car: 98,328i
try e46 fanatics
Old 08-23-2011, 12:02 AM   #8 (permalink)
njtl001 is on a distinguished road
Bushing
To be happy! That cutting blade & Circular Blades
njtl001 is offline   Reply With Quote
Old 08-28-2011, 11:03 PM   #9 (permalink)
Replaced Center bearing (metal bearing surrounded by rubber). The rubber had worn out of it. But, unfortunately the vibration is already back after two days, guibo is fine. Any other recommendations?
Old 08-29-2011, 06:45 AM   #10 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
RealOEM.com Online BMW Parts Catalog
This site usually has diagrams and part numbers !!
Eso es todo!
BMW Part Market
New Member ?
Old 08-29-2011, 02:32 PM   #11 (permalink)
I've reviewed that listing, but since I'm unsure what on the vehicle causes vibrations, it does not do me alot of good.
I'm hoping someone has had similar experiences and can tell me what worked for them?
Old 08-30-2011, 04:09 PM   #12 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Could be rotors or shaft balancing then (If you've covered the other bases)...
Eso es todo!
BMW Part Market
New Member ?
Old 07-03-2012, 12:07 PM   #13 (permalink)
alirzn is on a distinguished road
Hi,
I have a vibration on 20-27 miles like as you had before. Did you find out what was wrong? And did you solve it?
alirzn is offline   Reply With Quote
Abnormal Vehicle Vibration BImmerN2B 3-Series (E36) 2 08-11-2005 05:36 PM
Vehicle weight uglydumbguy 3-Series (E36) 10 11-26-2003 06:19 AM
Top 20 vehicle sales donutchow Other Rides 9 08-22-2003 10:20 PM
VEHICLE OF DEATH!!!!! DesmoBob Driving Tales 1 06-20-2003 06:07 PM
