Help! Tail warning light is on... - BMW Forum - BimmerWerkz.com
Old 06-24-2004, 12:52 AM   #1 (permalink)
ritius is an unknown quantity at this point
My right side tail warning light is on.. I did check the tail light and it's ok. Do you know how to solve this problem or reset it? ghead
ritius is offline   Reply With Quote
Old 06-24-2004, 06:31 AM   #2 (permalink)
Gargoyle69's Avatar
Gargoyle69 is an unknown quantity at this point
Just food for thought, pull the light bulb out and do a real good inspection of the bulb to include thbase of the bulb. My tail light indicator went off about two weeks ago and I checked the bulb and it looked fine, but the indicator was still on. I had too look at it real close a second time and when I did I noticed that the post that hold the filament looked like they where coroded. I went ahead and changed the bulb and the indicator went off. I am not sure if this is you cars problem or if you have already changed the bulb, but you might look into it.
Silver 2000 323i with sport package
Gargoyle69 is offline   Reply With Quote
Old 06-24-2004, 08:17 AM   #3 (permalink)
jkloese's Avatar
jkloese is an unknown quantity at this point
I had the same problem. At first it was just my front blinkers, The light would go on and off so I pulled the bulbs out and realized that somehow it was shorting and it melted the tip of the bulb. I just filed it down and put it back and no problems. My brake lights did the same thing.
<img src='http://www.bmw-forums.com/forum/index.php?act=Attach&amp;type=post&amp;id=18826.jp g' border='0' alt='user posted image' />
jkloese is offline   Reply With Quote
Old 06-24-2004, 02:21 PM   #4 (permalink)
Oh... thanks so much Gargoyle69 and jkloese. Great advise here.
I did change my bulb and it works.
Do we have to replace the bulb as often? compare to other cars? Just curious... :lol:
Old 06-24-2004, 04:59 PM   #5 (permalink)
Gargoyle69's Avatar
Well, Bulbs will be bulbs. I have had to change mine just like on all of my other vehicles. The cars may be better, but the bulbs are still made like they are for all other vehicles. Oh and guys welcome to the Forum.
Old 06-24-2004, 05:42 PM   #6 (permalink)
Thanks again.. Here is My Bimmer......
Old 08-07-2004, 05:38 PM   #7 (permalink)
ozzy is an unknown quantity at this point
can anyone tell me how to pull out the brake light bulb? my warning light just came on as well....thanks
ozzy is offline   Reply With Quote
Old 08-07-2004, 09:00 PM   #8 (permalink)
KillFox is an unknown quantity at this point
Send a message via AIM to KillFox Send a message via Yahoo to KillFox
The assembly on the E46 is extremely easy to remove, there is one button/clip that you pull inwards and the assembly pops out. The assembly holds all like... 5 bulbs that are in your tail light, just find the brake one and twist it one way and it will pop out. Then just insert the new bulb, push down and twist, and its good to go.
Then you simply place the assembly back against the housing, line it up, and push it in and the button/clip will click and you are good to go.
Very easy install
<img src='http://3dwire.net/~matt/killfoxsig2.gif' border='0' alt='user posted image' />
KillFox is offline   Reply With Quote
Old 08-08-2004, 11:43 AM   #9 (permalink)
komodo's Avatar
komodo is an unknown quantity at this point
Nice car Ritius. And welcome to the forums.
I've had some problems with the computer telling me "break light circuit" is having problems, and I changed the bulbs and it worked fine. BMWs are really sensitive when it comes to bulbs....
komodo is offline   Reply With Quote
Tail Light Help! Bimrboy 3-Series (E36) 5 08-06-2005 11:57 PM
COMPUTER CHECK - TAIL LIGHT FAILURE?!?? kraze0g 3-Series (E36) 3 06-25-2004 10:30 PM
Tail Light Warning Light Black530MT 5-Series (E12,E28, E34, E39, E60) 1 02-28-2004 05:20 PM
330CI LED Tail light conversion problem kwoktoa 3-Series (E46, E90) 2 02-05-2004 07:47 AM
