Help Required In The Uk - BMW Forum - BimmerWerkz.com
Old 02-02-2005, 03:00 PM   #1 (permalink)
SteveUK is an unknown quantity at this point
Hello across the pond
Do you think you could give me some simple advice?
I have an 2003 320Ci which is a 3 series 6 cylinder soft top model in UK speak
The engine has suddenly developed a lumpy feel and the yellow engine warning light has come on. It sounds as though the engine is misfiring on 1 cylinder. Unfortunately the local dealer cannot look at it until next week!
I need to check the plugs and the plug leads quickly - a relatively simple job so long as you know how to get access to them ... and I don't. There appears to be at least 1 plastic engine shield in the way with no obvious way of removing it. Does anybody know how to get access to the plugs?
Thanks
Steve
SteveUK is offline   Reply With Quote
Old 02-02-2005, 03:24 PM   #2 (permalink)
billB's Avatar
[attachmentid=17995]
Thanks
Steve
[snapback]284769[/snapback]
What you just called one plastic engine shield is your access to the plugs and their wires. Locate these little round 2 caps (see pic. above) pop it with a falt screw driver and lookfor little nuts; break them loose; the cover should come out easy....enjoy the rest.
regards
billb
Old 02-02-2005, 03:41 PM   #3 (permalink)
Bill
Thanks a load for the info. So obvious once it's been pointed out. I'll be on to it first thing in the morning.
Regards
Steve
Old 02-02-2005, 04:57 PM   #4 (permalink)
billB's Avatar
Originally posted by SteveUK@Feb 2 2005, 10:41 PM
Bill
Regards
Steve
[snapback]284794[/snapback]
do you need more pic. of what is under the plastic?
Old 02-02-2005, 09:29 PM   #5 (permalink)
Aloyouis is an unknown quantity at this point
I do please post!
Aloyouis is offline   Reply With Quote
Old 02-03-2005, 03:38 AM   #6 (permalink)
Bill
If that's not too much trouble, that would be just great
I'm much obliged
Steve
Gaskets Required mmclaren 3-Series (E36) 2 01-09-2005 05:07 PM
Is premium gas really required in 540i gear head 5-Series (E12,E28, E34, E39, E60) 4 09-18-2004 06:02 PM
Technical info required moonrider 3-Series (E46, E90) 0 08-28-2004 06:30 AM
Hard-top to soft-top conversion info required ivenner 3-Series (E21, E30) 4 06-02-2004 01:42 PM
Electric Expert Required deedee 3-Series (E21, E30) 1 03-18-2004 09:39 PM
