HELP!!! P0171 and P0174 - BMW Forum - BimmerWerkz.com
Old 05-20-2011, 11:03 AM   #1 (permalink)
chetshores is on a distinguished road
I have a 2003 BMW 325Ci. My SES light is on and I pulled the codes at i got P0171 and P0174 which says the car is running too lean bank 1 and 2.
The boot is not cracked or leaking.
I checked for any vacuum leaks with carb cleaner.
I cleaned the MAF.
I checked the fuel filter.
I dont think it would be the O2 sensors because its unlikely for them both to go out, but with my luck anythings possible.
Before i fork out the $300.00 for a new MAF anybody else got any suggestions?
PCV?
chetshores is offline   Reply With Quote
Old 05-20-2011, 11:17 AM   #2 (permalink)
Ccv?
Old 05-20-2011, 01:44 PM   #3 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
DON'T change the MAF !
Does it idle roughly or even misfire occasionally?
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 05-20-2011, 05:59 PM   #4 (permalink)
westin is on a distinguished road
ccv?what does it do if you don`t mind me ask, is there a pending code , can you check your maf with a scope pattern through your scan tool. you can check you other main sensor the same way to avoid any part swapping with no leads
westin is offline   Reply With Quote
Old 05-31-2011, 12:05 PM   #5 (permalink)
it does not idle rough or ever misfire. and i really dont want to change the MAF.....
Old 05-31-2011, 02:06 PM   #6 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Could be fuel pressure or tired injector(s)...
If the O2 sensors failed, I think it would run rich !!
Eso es todo!
BMW Part Market
New Member ?
2002 bmw e39 525i p0171 p0174 sytem too lean bank1 bank 2 help? my bimmer 2002 5-Series (E12,E28, E34, E39, E60) 7 03-27-2010 04:05 AM
P0171&P0174 codes pop up. anyone have a clue?? coolcooltracy 3-Series (E46, E90) 4 11-02-2009 05:19 PM
p0171 and p0174 code help,,01 740i bosanci28 1,6,7,8 - Series and Mini Cooper 2 05-13-2009 08:31 AM
Intake boots, and lean P0171 P0174 codes longrob 5-Series (E12,E28, E34, E39, E60) 2 03-23-2009 03:50 PM
Obd Code P0171 Sporty540 5-Series (E12,E28, E34, E39, E60) 6 07-19-2005 10:26 PM
