I just reseted the check engine and the scanner read fault code 92. How can I fix the fault code? Or can anyone tell me what it means or what it does because im not faimiliar with it.
A fault code 92- EVAP Capillary Leak (0.5mm) detected
Check your gas cap, it may not have been put on right or tight enough. Try that then clear the code and see if it pops up again. If the code pops up again then you may have a leak in the fuel system. I could be fuel vapor leak or a fuel leak in the system.
Related Threads
BMW Werkz
668.8K posts
97.6K members
Since 2003
