Help Help Help Help Help Help Help - BMW Forum - BimmerWerkz.com
Old 09-29-2008, 02:24 PM   #1 (permalink)
titaniumbullet's Avatar
titaniumbullet is on a distinguished road
Send a message via MSN to titaniumbullet Send a message via Yahoo to titaniumbullet
I really need help on this.. I have a 2003 E46 and I have had issues with it starting.. I dont know what is going on with it its giving me such a hard time. I had attemped to start it and it wouldnt start. I heard no clicking or anything so I tapped the selonoid on the starter and still nothing. I REALLY need my car. any ideas on whats wrong?
:he lp
My favorite BMW rims
titaniumbullet is offline   Reply With Quote
Old 09-29-2008, 02:47 PM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
do all the dummy lights come on?
1992 318i Coupe parts car
I am Captain Obvious
Old 09-29-2008, 02:48 PM   #3 (permalink)
yea.. it doesnt look like its a battery issue Im so pissed.. Jump on MSN Nick
Old 09-29-2008, 09:10 PM   #4 (permalink)
zibby's Avatar
Car: yes
That could be a few things :
-EWS module error
-ignition switch faulty
-automatic transmission parking/neutral switch faulty(if your car is auto)
-alternators` solenoid(banging on it ,not always helps !)
http://www.q8oils.it/
Old 09-29-2008, 09:48 PM   #5 (permalink)
Moderator
Dirty_Tool's Avatar
Key failures are fairly common. Do you have another key you can try?
Do this to see if it is related to the key/EWS system:
Roll down the windows. From the outside of the car insert the key in the drivers door. leave it there and now get in the car and sit in the drivers seat. reach out the window and use the key to lock the car via the driver's door lock cylinder. Remove the key from the door and now put it in the ignition and turn ignition to position 2. IF the key is recognized and the EWS system is working then you should hear the door locks make a noise which means that the EWS system is taking the car out of "double lock" mode so that you can safely get out of the car. if this does not happen then you know that the problem lies somewhere in the EWS system whether it be a bad key, bad module etc. Most common thing is just a faulty key.
regards,
DT
Old 10-02-2008, 12:21 PM   #6 (permalink)
EWS system failure... that what it was... I have a spare key so I think Im ok.. Ill def be back if something is a mis.
