Help! Headlight / Electical Issue - BMW Forum - BimmerWerkz.com
Old 09-28-2009, 11:30 AM   #1 (permalink)
SurfaRiver is on a distinguished road
Hello,
I was driving home in my 06 325xi on Saturday night and a headlight warning came on (looks like a yellow D with a '!' in the middle) and low and behold, neither of my low beams worked.
The fog lights work, the daytime runnings work, the parking lights work, the "flash to pass" works. While the "flash to pass works", the high beams will not stay on when I push the level out (they have intermittently since Saturday, but they are not working now).
I checked the 3 fuses in the box that are supposed to be wired to the lights and they all work. I replaced the passengers side low beam (the old bulb looked fine) and it still didnt work.
I bought the car new in 10/05 and have done no mods. They are regular bulbs, not the HID ones. Any thoughts? I'm starting to think I'm in trouble and am going to have to take it in to BMW and pay $130/hr to get it fixed.
Thanks!
Mark
SurfaRiver is offline   Reply With Quote
Old 09-29-2009, 08:52 AM   #2 (permalink)
ouch! 31 views and no replys, thats probably a bad sign.
2nd question: This will be my first service since its been out of the warrantee. Should I take it back to the dealer to check this problem checked out, or can someone recommend a good shop around Boston (metro west / south shore)?
Thanks!
Mark
Old 09-29-2009, 09:00 AM   #3 (permalink)
Sounds like the low beam relay went bad on you. I don't think I would take it to the dealer unless there are no good BMW indy shops around you.
You could probably replace the relay yourself, but I am not sure where it is located in the 325.
FCP Groton
877-634-0063 | info@fcpgroton.com
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
FCPGroton is offline   Reply With Quote
Old 09-29-2009, 09:01 AM   #4 (permalink)
I would think the first things to check would be the switch and in line circuit breaker.
Old 09-29-2009, 09:18 AM   #5 (permalink)
Awesome, so it sounds like it should check the low beam relay, switch or in line circuit breaker.
I have a great deal of experience working on my 79 mustang, but obviously this car is a whole different story and I've got to say I'm a little bit intimidated.. Should I assume that I can access those 3 items from under the dash? The "light switch" itself is on the left of the consol under one of the vents.
Thanks!
Old 09-29-2009, 09:19 AM   #6 (permalink)
You may be able to narrow it down on realoem.com
Old 09-29-2009, 01:43 PM   #7 (permalink)
CanadianWraith's Avatar
Car: 1996 318is
CanadianWraith is on a distinguished road
+1
should be under the dash, drivers side
CanadianWraith is offline   Reply With Quote
Old 09-29-2009, 04:02 PM   #8 (permalink)
alright, I've got the switch out, since that was the next easier thing to get out of the car. I'm not sure how I'm going to go about testing the switch.
Its got 12 pins and if I knew which pin did what, I'd just use a paperclip to make the connection on the harness and see if the low beams worked.
That realoem is great, I now know where to order the switch if that turns out to the the problem.
Where might i find a pin diagram for the switch?
Thanks!
Headlight upgrade from non zenon headlight to zenon headlight ro0310 5-Series (E12,E28, E34, E39, E60) 8 03-30-2009 08:13 PM
Roof issue red light flashing! (and Sat Nav issue too!) doopranal Z3 / Z4 /ZM 0 03-24-2009 06:25 AM
anyone else with this issue ericadair 3-Series (E46, E90) 2 12-13-2008 12:07 AM
headlight issue theironm0nk 3-Series (E36) 6 11-23-2005 01:45 AM
I Need A Headlight Prism Or Headlight 528man Classifieds Sell & Buy 0 04-06-2005 09:37 PM
