Help Deciphering Code - BMW Forum - BimmerWerkz.com
Old 02-05-2005, 08:47 PM   #1 (permalink)
oscaroc is an unknown quantity at this point
My car won't start it is a 01 325i auto and it threw two codes P0491 and P0492 can anyone help? thanks
oscaroc is offline   Reply With Quote
Old 02-06-2005, 04:34 PM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
[snapback]286602[/snapback]
Respond with the last 7 digits of your vin # and i can decode those for you.
DT
DT
Old 02-06-2005, 05:53 PM   #3 (permalink)
last seven are FU89283. thanks
Old 02-06-2005, 07:19 PM   #4 (permalink)
Moderator
Dirty_Tool's Avatar
P0491 Secondary Air Injection System Insufficient Flow (Bank 1)
P0492 Secondary Air Injection System Insufficient Flow (Bank 2)
Those are the faults.... if the car is not starting this is not the cause. Most likely the codes are alerting you as to a failed secondary airpump. If you find that it is indeed failed then check and/or replace the 1 way valve which goes inline with the pump.
Once again this will not cause a no-start condition. Does the engine crank over but not start? Or is it not cranking at all? Have you tried jump starting etc? Give us some more info on what its doing and maybe somebody can help.
DT
DT
Old 02-06-2005, 07:35 PM   #5 (permalink)
It does cranks but it never fires, it gets close but no cigar. Thanks for the info too by the way. I appreciate it. The only thing I have done with the car in the last week is drive it to put gas in it. i would like to find what is wrong it is very peculiar
Old 02-07-2005, 03:51 PM   #6 (permalink)
Moderator
Dirty_Tool's Avatar
Perhaps a bad fuel pump? You can try having some1 else crank over the car while u lay down and pound on the fuel tank a bit with a rubber mallet or the palm of your hand and see if it fires. Sometimes this will jar the pump into working. Or if you wanted to get technical you could use a guage to check the fuel pressure. :P
If you have fuel pressure of course the next thing to check would be spark.
And of course if worse comes to worse you can always take it to a professional and have it diagnosed.
Best of Luck
DT
DT
Old 02-07-2005, 06:34 PM   #7 (permalink)
What is typical for fuel pressure? I checked with just the key on it was about 20 psi.
Old 02-07-2005, 07:02 PM   #8 (permalink)
mark1411 is an unknown quantity at this point
DT
[snapback]286993[/snapback]
I too have the same exact codes. Just read today at Schucks Auto on My 2001 325 xi with 34,000 miles. My Service Engine Light has been on for about 3 days now, but the car seems to be running just fine. Any ideas for an easy check or fix before taking it into a pro?
Thanksl
Mark
mark1411 is offline   Reply With Quote
Old 02-07-2005, 07:29 PM   #9 (permalink)
Moderator
Dirty_Tool's Avatar
[snapback]287553[/snapback]
Fuel pressure should be at 3.5bar with engine on and idling.
DT
DT
Old 02-07-2005, 07:54 PM   #10 (permalink)
Moderator
Dirty_Tool's Avatar
Originally posted by mark1411+Feb 7 2005, 05:02 PM--><div class='quotetop'>QUOTE(mark1411 @ Feb 7 2005, 05:02 PM)</div><div class='quotemain'><!--QuoteBegin-Dirty_Tool@Feb 6 2005, 07:19 PM
P0491** Secondary Air Injection System Insufficient Flow (Bank 1)
P0492** Secondary Air Injection System Insufficient Flow (Bank 2)
DT
Thanksl
Mark
[snapback]287585[/snapback]
[/b][/quote]
Mark,
Once again this is most commonly a failed pump. Check fuses # 3 and #36. If they are good you can try jumping the secondary air pump relay (behind RH footwell trim) and seeing if the pump runs. If it doesnt run confirm it has power and ground and if so replace the pump, as well as the 1 way valve. The 1 way valve often causes pump failure by allowing condensation into the pump.
Note: fuses and component location are for E46 and should be confirmed in the Bentley manual for anyones specific vehicle. Do not take my word for it
DT
DT
Old 02-07-2005, 11:12 PM   #11 (permalink)
Thanks DT.
I've check the necessary fuse #36 and it is o.k. I'm not sure how to jump the relay to see if the pump works and or test for power and ground. But I may be able to change the pump and valve. Is that pretty straight forward?
Also, should I be hearing the secondary air pump turn on every cold start? And is it o.k. to drive the car for awhile with a broken secondary air pump?
Thanks again for you help.
Mark
Old 02-08-2005, 08:30 AM   #12 (permalink)
Yeah thanks for your help it is appreciated.
I was told that if your secondary air system is non operational that it would be the cause of not being able to cold start the vehicle. But that doesn't seem right it should still fire even it it runs crappy. I could be wrong
Do i need to crank the the motor over to check fuel pressure? Or just turn the key and take a reading?
I know i need to get the bently book! I have an audi A4 book but that doesn't help any here
Old 02-09-2005, 10:10 AM   #13 (permalink)
Moderator
Dirty_Tool's Avatar
Originally posted by mark1411@Feb 7 2005, 09:12 PM
Thanks DT.
Mark
[snapback]287742[/snapback]
Its a really straightforward job to replace the valve and pump. It wont hurt the car at all to run it for a while without the pump, this is a smog component which only runs during the 1st 90 secs of engine warmup anyway. Yes you should hear it on every cold start.
DT
DT
Old 02-09-2005, 10:11 AM   #14 (permalink)
Moderator
Dirty_Tool's Avatar
[snapback]287838[/snapback]
Yes check fuel pressure while cranking, not just with the key on. Secondary air pump will absolutely not cause a no start condition or even a rough running condition. Merely a smog component.
DT
DT
Old 02-09-2005, 09:28 PM   #15 (permalink)
Thanks DT!
I can hear the pump noise on cold start up and can even feel air running through hose, so I'm going to assume it was a momentary fault of some kind that set off the service engine soon light.
I just got a Peake scan tool and turned off the SES light, so lets hope it stays that way. By the way do you think the Peake scanner is a good one? Thanks again.
Mark
E30 Anti-theft Radio Code aaronhoy 3-Series (E21, E30) 4 06-08-2009 11:40 AM
Strange Fault Code ben_t 5-Series (E12,E28, E34, E39, E60) 0 04-02-2005 06:53 AM
Dwa/ews Input Peake Fault Code? jday 5-Series (E12,E28, E34, E39, E60) 8 02-04-2005 09:19 AM
Asking For Code jshearer Audio and Electronics 1 12-18-2004 08:28 PM
stereo/radio anti-theft code xristo 3-Series (E21, E30) 3 03-02-2004 04:18 PM
