HELP Airbag Light - BMW Forum - BimmerWerkz.com
Old 09-01-2006, 07:01 PM   #1 (permalink)
737flyer is on a distinguished road
HELP Airbag Light
I replaced my passenger side window regulator and the airbag light came on after hooking everything back up. The initial fault I got was supply power. I think that I damaged the connector that goes to the airbag so replaced the wiring harness in the door. Then a new fault showed up , firing circuit side aribag front right. I then replaced the airbag. Still the same fault exists.
What should I do?
Do you think the harness I got was defective? Should I replace it again.?
I am using a peake airbag reset tool. It will not let me reset the codes because the circuit fault still exist.
737flyer is offline   Reply With Quote
Old 09-04-2006, 12:22 AM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
could be a faulty harness. You need to ohm through the entire circuit and see what the resistance is. it shouldnt be more than about 6 ohms. you can remove the A-pillar and use the pins there to ohm through the entire door.
good luck
DT
Airbag Light??? RockyMan1980 3-Series (E36) 13 08-26-2008 12:35 AM
1997 740iL airbag light on ozbmw 1,6,7,8 - Series and Mini Cooper 1 11-11-2005 03:18 PM
Airbag Light Aggravations kestrel325is 3-Series (E36) 3 04-07-2005 10:35 AM
Airbag Light Rodrigo 3-Series (E36) 12 04-02-2005 07:52 PM
