Hello~ Inspection~ and airbag light T.T - BMW Forum - BimmerWerkz.com
Old 02-02-2004, 10:25 PM   #1 (permalink)
junchoi is an unknown quantity at this point
trying to get car inspection at dealer...
is it better to get inspect at dealer or just auto shop?! thank you~
They said it cost $140.....
my second problem is the airbag light got on!!!
man... itz been only a week... and already getting problems?!
anyway to fix it or take it to the dealer and fix it?!!~
thank you.....
junchoi is offline   Reply With Quote
Old 02-03-2004, 10:09 AM   #2 (permalink)
mankiks323i's Avatar
mankiks323i is an unknown quantity at this point
inspection can be done by yourself if you have a little know how about cars like looking at hoses any visible leaks and check brakes for wear by looking at pads and rotors peeking under the car and suspension for any visible problems. Changeing oil is fairly straight forward around fifty dollars if you do it yourself for oil and filter synthetic of course. As for your airbag light i have had problems with mine going on several times. i think there is an issue with the seatbelt latch on the drivers side i had mine replaced. Or you can buy a reset tool from peake research but they are a little expensive and you will end up using it maybe once. If your car is under warranty take it to the dealer let them fix the airbag light. I know my car had some airbag issues they finally fixed and has not lit up and stayed on
"What happens here stays here" Las Vegas
mankiks323i is offline   Reply With Quote
Old 02-03-2004, 06:39 PM   #3 (permalink)
EXtech's Avatar
typical problems with e46's and airbag lights are the seat buckle switches and passenger seat occupancy sensors. Occasionally there were faulty airbags or moisture collecting in the a-pillar/door jamp bulk connector and also a harness modification/update. Either way, take it to the dealer for the warranty.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 02-03-2004, 07:29 PM   #4 (permalink)
TECH's Avatar
Inspection 1 or 2? Basically, not a whole lot involved with either. Change oil and filter, microfilter, and air filter (if it's an insp 2), plus a bunch of checks.
SRS light, could be any number of things.
Old 02-24-2004, 12:07 PM   #5 (permalink)
Blackdog is an unknown quantity at this point
Yeh my air bag light just came on a week ago. I took it to BMW and it is going to be around 750 for a new bag. I have never heard of so many problems with a airbag in a car before. Cheap a@# bags!
Blackdog is offline   Reply With Quote
Airbag Light??? RockyMan1980 3-Series (E36) 13 08-26-2008 12:35 AM
1997 740iL airbag light on ozbmw 1,6,7,8 - Series and Mini Cooper 1 11-11-2005 03:18 PM
Airbag Light Does Not Come On! zayd55 5-Series (E12,E28, E34, E39, E60) 1 08-29-2005 11:40 AM
Airbag Light Aggravations kestrel325is 3-Series (E36) 3 04-07-2005 10:35 AM
Airbag Light Rodrigo 3-Series (E36) 12 04-02-2005 07:52 PM
