Headlight Problem - BMW Forum - BimmerWerkz.com
Old 01-10-2005, 09:28 PM   #1 (permalink)
zwke36 is an unknown quantity at this point
Hi, I had my right headlight low beem bulb replaced at my dealership today, and when I drove at night, it looked as if the new light was pointing straight at the ground, and the light pattern on the light was slightly different then that of the exsisting bulb (the old one had a more defined top line). However, the highs/Daytime running lights were level, though the lows werent. Is there a chance they put the wrong bulb in, because when i leveled the low beams, the high beams were unleveled, though I guess all that really matters is the low beams? Is there anyway to just adjust the low beam bulb, which seems to be pointing low.
btw, this is on my 2000 323i w/ halogens
zwke36 is offline   Reply With Quote
Old 01-10-2005, 09:39 PM   #2 (permalink)
Rooz's Avatar
Car: 2003 M5
They probably broke the bulb support when they replace it, my suggestion, go back to them tell them to fix it
VIEW MOD LIST & PICS
Originally Posted by Gregg
Rooz is offline   Reply With Quote
Old 01-10-2005, 10:02 PM   #3 (permalink)
[snapback]268602[/snapback]
thanks, think they'll fix it free of charge?
Old 01-10-2005, 10:33 PM   #4 (permalink)
TECH's Avatar
Originally posted by zwke36+Jan 10 2005, 10:02 PM--><div class='quotetop'>QUOTE(zwke36 @ Jan 10 2005, 10:02 PM)</div><div class='quotemain'><!--QuoteBegin-Rooz@Jan 10 2005, 09:39 PM
[snapback]268628[/snapback]
[/b][/quote]
Sometimes, the whole inside of the light can break away from the main housing. Grab the bulb at the connector, and move it up and down a bit.........feel too loose?
Old 01-11-2005, 06:16 AM   #5 (permalink)
how do i get the glass/plastic out? is it just held in by those clips, or something else?
Old 01-11-2005, 09:32 AM   #6 (permalink)
TECH's Avatar
[snapback]268797[/snapback]
The light can be removed and disassembled......it MAY be fixable, but replacement parts aren't available seperately, that I know of. Salvage headlights may be your best bet IF that is your problem.
Old 01-11-2005, 11:11 AM   #7 (permalink)
before you disassemble the headlight try adjusting the aim. there are little holes thru which you can stick a phillips and turn.
Old 01-11-2005, 04:12 PM   #8 (permalink)
Rooz's Avatar
Car: 2003 M5
They should, just tell them you didn't have that problem before they "touched" your lights
Old 01-11-2005, 07:25 PM   #9 (permalink)
[snapback]268881[/snapback]
oh, so it's possible to adjust the induvidual headlights? Cause thats what I need to do, anyone have a picture showing where the holes are? If not, I'll just take it back to the stealer and get them to fix it.
Headlight problem: City lights don't work (low and high beam do) KILOCHARLIE 3-Series (E36) 4 09-21-2005 01:33 AM
'98 540i Headlight Problem ericmalkoc 5-Series (E12,E28, E34, E39, E60) 1 06-30-2005 08:34 PM
Problem With My P36 Headlight Angel Eyes JV2000 Audio and Electronics 0 01-29-2005 05:10 PM
Headlight problem kylejt 5-Series (E12,E28, E34, E39, E60) 5 06-16-2004 04:44 PM
525 headlight problem....help please Tel 5-Series (E12,E28, E34, E39, E60) 5 09-02-2003 07:02 AM
