Have a check engine light? - BMW Forum - BimmerWerkz.com
Old 04-07-2006, 05:35 PM   #1 (permalink)
441tech's Avatar
441tech is on a distinguished road
Post Have a check engine light?
My '99 323i E46 recently spit 2 codes, P1421, P1423. My scanner told me it was "Manufacturer Controlled Secondary Emissions." Well, with some help from you guys, and some simple troubleshooting, and the factory service manual, I fixed it without shot-gunning any parts.
Turns out, the secondary emissions system basically consists of an air pump, secondary valve, and a control solenoid valve underneath the intake manifold. Usually, air solenoid valves don't normally puke, so I took the pump off the right shock tower and zapped 12V on the terminals--nothing. It's also recommended that you change the secondary pump and valve together, as one can take out the other in the event of a failure.
So, $330 later--MY COST: --but only about 45 min. for R&R, my check engine light remains out to this day. Plus I can hear the pump right on the first start of the day now, which I couldn't hear before. It actually sounds kinda cool, especially when it shuts off.
I can't STAND idiot lights on in my car. As a mechanic, I just gotta fix it I guess--no matter what the cost, and even if it doesn't affect the way it runs.
Also, there are some parts stores around the country, such as Autozone, that will tell you what the code is from your check engine light for free. That's the benefit of OBD II systems--it's a common language now worldwide in cars. Or, for $100, you can pick up your own OBD II code reader and take it from there. Caution: If you do this, have a manual handy to help explain what the code means, or ask someone here!
I just think a BMW should work properly, don't you think?
441tech
Officer: "I see you set the table for four."
Groucho Marx: "That's nothing--I set my alarm clock for eight."
441tech is offline   Reply With Quote
Old 04-07-2006, 05:47 PM   #2 (permalink)
Retired administrator
triggrhaapi's Avatar
not to brag or anything... but the check engine light on OBD I BMWs will dump the error codes if you do a neat little pedal dance. Saves you the trip to autozone or the $100 for a scanner.
Addicted to Speed Since 1997
Old 04-08-2006, 12:45 AM   #3 (permalink)
325isBaby's Avatar
Car: 2005 330xi
441tech
Then I'd be out of a job J/K but as far as things go on the tech side, deffinatly my favorite car to work on
Come see me at MySpace
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
Check Engine Light aheath 3-Series (E36) 1 04-27-2005 06:27 PM
Check Engine Light On, But Only When I Start Car BMW-ATI 3-Series (E36) 5 04-15-2005 09:40 PM
Red check engine light came on today YNGRVP 3-Series (E36) 9 05-28-2004 09:36 PM
Check Engine Light came on today camnipotent 3-Series (E36) 22 05-17-2004 06:23 PM
