H&R Coilovers - BMW Forum - BimmerWerkz.com
Old 03-01-2004, 05:13 PM   #1 (permalink)
asiangear's Avatar
asiangear is an unknown quantity at this point
Knowing that coilovers are adjustable, I was wondering how would one exactly adjust them? Do you have to access it from the bottom, through the wheel well, or is it adjusted from the top of the shock tower? If I get coilovers, would I need to modify my trunk liner in order to have access to the shock towers? Thanks for any help. ^_^
<span style='color:blue'>Stock 323 Ci 2000 Coupe-
-Stock Performance Package (17&quot;rims and suspension)</span>
<img src='http://www.peachprincess.com/Merchant2/images/bs_chr5.jpg' border='0' alt='user posted image' /><img src='http://www.sighost.org/sigs/sakesan.jpg' border='0' alt='user posted image' /><img src='http://www.peachprincess.com/Merchant2/images/bs_chr4.jpg' border='0' alt='user posted image' />
asiangear is offline   Reply With Quote
Old 03-01-2004, 06:50 PM   #2 (permalink)
e36_m3_Turbo's Avatar
you have to lift your car up to turn the sleeve bolt that goes on it, and it comes with a tool that helps you turn that bolt
No longer red.
Old 03-01-2004, 08:23 PM   #3 (permalink)
asiangear's Avatar
H&R Coilovers Adjuster Picture
Here is a picture of the HR coilovers and the adjuster. I think this is a new type of adjuster HR released. Does anyone know if the way you adjust it is the same method as described by e36_m3_Turbo? If it is adjusted from the bottom of the car, does that mean I don't have to punch holes into my trunk liner to adjust the rear shock heights? Can someone can show me a DIY site or some type of guide that shows how to adjust the height of HR coilover or coilovers in general? Sorry, I'm totally clueless as to how coilovers exactly work and would like to know how to work with them before buying. ^_^
Old 03-01-2004, 10:42 PM   #4 (permalink)
ex owner/admin
Furious's Avatar
where are you buying them from? because our sponsor can get a good deal on them. check with him before you buy, maybe youll get a better deal.
Old 03-01-2004, 11:10 PM   #5 (permalink)
bimmerfan620's Avatar
bimmerfan620 is an unknown quantity at this point
Send a message via AIM to bimmerfan620 Send a message via Yahoo to bimmerfan620
If you honestly do not understand suspension modifications such as the Operations of a Coilover system, then I would not suggest tuning them yourself without the assistance of a proper tuner/mechanic. It can become a bit of a pain when trying to get all 4 sides to the proper height; as well as, whenever you change them you need to get a new alignment.. Doesn't serve a street car much of a purpose as you'll most never change them once you set them to what you like....
FOUNDER of the BMW-Forums Michigan Club
<span style='color:green'><a href='http://www.cardomain.com/memberpage/458339' target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1078289877.jpg' border='0' alt='user posted image' />
bimmerfan620 is offline   Reply With Quote
h&r coilovers VS Bilstien coilovers socalguy 3-Series (E36) 2 07-22-2004 09:47 PM
coilovers? krazykappy 3-Series (E36) 1 07-04-2004 02:03 PM
Coilovers Arcade 5-Series (E12,E28, E34, E39, E60) 2 06-16-2004 07:14 PM
springs vs coilovers socalguy 3-Series (E36) 9 04-15-2004 12:12 AM
Coilovers on, found something else cool out! Scarface 3-Series (E36) 14 12-08-2003 09:31 AM
