Funny smell coming from air vents? Filter? - BMW Forum - BimmerWerkz.com
Old 02-13-2006, 11:26 AM   #1 (permalink)
Ocean02 is on a distinguished road
I noticed last week when the weather got warmer out here (southern Califormia) that the air coming from my vents when the A/C is cold smells like stagnant urine or something (not quite that bad, but it's not pleasant). Should I replace some kind of filter? Where is it, and how do I do this?
Ideas?
Ari Cohen
2002 BMW 325i
5spd manual
Ocean02 is offline   Reply With Quote
Old 02-13-2006, 11:50 AM   #2 (permalink)
storme's Avatar
storme is an unknown quantity at this point
it is mould
turn your a.c on full blast....and turn the temperature settings upto full(32degrees )
leave it for a few minutes...then turn the temp setting down to its minimum setting and run it for a few minutes
i also sprayed some disinfectant thru the filter element under the hood...
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Old 02-13-2006, 12:01 PM   #3 (permalink)
Good tip, man! Where exactly is the filter element? I suppose I could just look in my owners' manual, but I figured I'd ask since I'm sitting here at the computer...
Ari Cohen
2002 BMW 325i
5spd manual
Old 02-13-2006, 01:01 PM   #4 (permalink)
Hootie is on a distinguished road
Cabin air filter is under the hood, centered just infront of the windshield. It's covered by a plastic housing with 3 turn screws. Filter can be replaced in about 15 seconds...
Hootie is offline   Reply With Quote
Old 02-13-2006, 01:02 PM   #5 (permalink)
storme's Avatar
lift up the front hood(bonnet)
just below the screen wipers is a black plastic shroud
it has 3 screws coming from it
open these screws
lift up the shroud
and there is a white elemt(unless it is filthy)
pull out this element
and spray some spray disinfectant down there...make sure a/c is on full
i do mine once a yr,,and have had no adverse reaction
the hardest thing for u will be finding the element
Old 02-13-2006, 01:27 PM   #6 (permalink)
Right on! Anyone know where to get these elements? I'll try some Lysol tonight, but just thought I'd ask. Also, can I just clean the element with some dish soap and warm water or something?
Ari Cohen
2002 BMW 325i
5spd manual
Old 02-14-2006, 11:29 AM   #8 (permalink)
Great, thanks Hootie. I did clean the filter with water and disinfectant spray. I cleaned out the filter box and blasted the spray though the holes with the A/C on full blast. Hope that will help.....
Ari Cohen
2002 BMW 325i
5spd manual
Old 02-15-2006, 12:59 PM   #9 (permalink)
Well, the smell isn't as bad, but still there. I think I'll just get a new filter soon. Meanwhile, I am stupid and forgot which way the filter goes in the housing. The owner's manual just says "Take to a certified technician, blah, blah blah..."
Fuzzy side up, or down?
Ari Cohen
2002 BMW 325i
5spd manual
Old 02-15-2006, 02:19 PM   #10 (permalink)
storme's Avatar
if it isnt as bad,,,,do it again next week....and run it on full hot then full cold a few more times....it will go away...
also you can get9here in the uk) some a/c disinfectant from various car centres...
it sprays disinfectant into the cabin...and with the a/c on full and in recirculation mode.....it sucks in the air from the cabin and eeps recirculating it for 10 mins
try and find some of that stuff....
ps serrations go down
Old 02-15-2006, 02:44 PM   #11 (permalink)
Storme's the man. I didn't get what you said about
"also you can get9here in the uk) some a/c disinfectant from various car centres..."
What do you mean? I did use a generic disinfecant, but only on cold A/C, not hot. I'll try again this weekend.
Oh, which way does the filter go in? Fuzzy side up or down? I put it facing upward (I think that's how it was in before). I want to make sure the cover seals correctly and no air can get around the filter.
Does anyone have a photo of the properly installed filter? My owners manual doesn't mention how to remove this or install it.
Ciao,
Ari
Ari Cohen
2002 BMW 325i
5spd manual
Old 02-15-2006, 03:14 PM   #12 (permalink)
storme's Avatar
http://www.motabitz.com/index.php?cPath=160_161
try this link,,,,,its a uk site...but is for illustration purposes....it is a spray disinfectant....and it goes inside the car....
u press the button and it releases the disinfectant and a nice smell,,for 10 minutes...your a/c is set to full heat and full fan and recirculation mode for 10 mins
Old 02-15-2006, 10:46 PM   #13 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Nothing is worse than the smell of an E39 5 series climate control system. The E46 shares some of its bad habits. Basically, the problem is mold; on the E39 I'm pretty sure it grows on the evaporator. The disinfectant method offered above is the cheapest way to deal with it.
Lindsay fan club member.
Old 02-16-2006, 06:03 AM   #14 (permalink)
also: some people say that (if garaged) cracking the windows open lets it dry and minimizes the problem.
Old 02-16-2006, 07:33 AM   #15 (permalink)
Oxygen bombs baby! Gotta love 'em.
http://www.topoftheline.com/odbomairvens.html
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
Funny Smell robbycor 5-Series (E12,E28, E34, E39, E60) 6 06-18-2005 07:22 PM
Funny Smell While I Drive The Car? tyro2001 3-Series (E21, E30) 15 03-12-2005 09:47 PM
Smokysmell Coming From Vents In Car. fdeee 5-Series (E12,E28, E34, E39, E60) 13 12-06-2004 11:51 AM
A funny smell bobs530i 5-Series (E12,E28, E34, E39, E60) 9 07-07-2004 01:31 AM
