Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 01-11-2005, 11:12 PM   #1 (permalink)
Photos: 0
bmw_in_maryland is an unknown quantity at this point
This is regarding a 2001 BMW 325xi. Last year, all four tires on our 325xi were reaching the end of their normal life (~55k miles) so we took them in for replacement. We also had the the alignment done at the time. Its my wife's car and she immediately said the car felt "different". We took it back to the tire dealer and they assured us it was just the fact that we had new tires and the alignment had changed the feel slightly.
These new front tires wore very fast; they went bald in about 10k miles. We took these back to the same dealer who basically gave us new front tires for free and checked the alignment. We thought it must have been that the initial alignment had been bad. It was, but for the wrong reasons.
I was changing the brake pads on all four tires a few weeks ago (about the limit of my mechanic ability) and found that the front left drive shaft has a LOT of play in it. When I raised the front right tire (using the correct jack and jack location) to replace the pads, the wheel was rock solid; no play. When I then raised the front left tire, I noticed that the wheel had at quite a bit of play. In retrospect, we had noticed the car wandering some, but had stupidly accepted it. The drive shaft to the front left tire moves in and out about 1/4 inch. In just the right circumstances (driving downhill, making a gradual right turn, followed by a sharp right turn) we could feel the steering "pop". We now realize that was the front left tire suddenly shifting.
I'm not much of an auto mechanic (I'm an aircraft avionics design engineer), but the few times that I have seen alignment done, the vehicle was driven onto a fixed platform and the caster, camber, toe-in, etc were all measured with the wheels stationary. I am guessing the guy who did the alignment (I was not there for this one) must have parked the car and the left wheel happened to be at one extreme of its play. He set the alignment like that, but as soon as the car came off the alignment jig, the play allowed the alignment to go out of wack and the tires immediately starting wearing bad.
My questions:
Is it possible this damage was done by the initial tire installation and alignment or is it more likely that is happened as a result of everyday driving (say right before or right after the initial tire installation and alignment) ?
Why would the tire installers not have noticed that the left front wheel had this kind of play either time they installed new front tires ?
Has this happened to anyone else?
What kind of repair costs are we looking at?
Any other comments?
I appreciate any inputs on this. I am not much use for autos, but if you have any aircraft related questions, please ask. [I know - wrong forum.]
Chris
bmw_in_maryland is offline   Reply With Quote
Old 01-12-2005, 03:08 PM   #2 (permalink)
Photos: 0
does this make a noise when turning, aside from the pop?
do you see any tears in the rubber boot covering the shaft?
do you have the alignment spec sheet before and after (x2 now)?
Old 01-12-2005, 08:54 PM   #3 (permalink)
TECH's Avatar
Photos: 0
E46 vehicles very commonly have control arms that wear out, and cause a lot of play. The actual driveshaft wouldn't cause your problem, it's the suspension. The suspension problem could also damage the driveshaft in time, so it needs to be fixed quick.
I'd say that one or both of the front control arms is worn at the ball joints and/or the bushings. Both of those items are commonly wearing and causing a lot of play.
If it's the control arm, go ahead and do the bushings too, since they come off anyway.
And any alignment shop that knows what they are doing would check the condition of the suspension before "aligning" it.
You can't properly align a car with worn parts.
Old 01-13-2005, 12:22 AM   #4 (permalink)
Photos: 0
Thank you very much for the replies. The only sound is the pop. The rubber boot is not torn. Yet.
We are taking it in to BMW tomorrow and letting them have it. I agree that the alignment shop should have caught the loose arms/suspension. If the slop was there the last time, and it must have been because the tires wore so quickly, I can't understand how they could have missed it. Needless to say, we won't be going back to that shop.
Thank you all again.
Chris
Old 01-13-2005, 07:44 AM   #5 (permalink)
Photos: 0
everything points away from a worn cv joint, so like tech said, it is not driveline problem.
i am still perplexed by the sudden nature of the change: if you are close to baltimore i would recommend taking the car to my mechanic, david bord (david's classic car shop), he works on the MECHANICALS of my bmw, and everything on my land cruiser and mercedes ('62 220).
i had decent luck with northwest bmw in owings mills, and horrible at towson.
vB code is On
E32 Drive shaft Problems edbolz 6,7,8,X,Z - Series and Mini Cooper 1 04-21-2004 03:49 AM
Another worthy competitor to the 3-series? AZ325Ci Other Rides 9 10-23-2003 07:08 PM
BMW Ultimate Drive SoonerE39 Bimmer Talk/Motorsports Talk 8 06-13-2003 05:29 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
