found sludge inside da valve cover!!! - BMW Forum - BimmerWerkz.com
Old 08-24-2008, 01:13 PM   #1 (permalink)
Car: 2000 bmw 328i
liljavier is on a distinguished road
i found sludge inside the valve cover anyone knows what i should do???/
liljavier is offline   Reply With Quote
Old 08-24-2008, 01:27 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Wink
do a motor flush next change oil... then use a detergent oil to clean your engine.
Old 08-24-2008, 01:43 PM   #3 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
while you have the valve cover off clean as much as you can out. Also run about 1/3 or a can of Seafoam through it.... Add it on the last 1500 miles..... do that on your next 2 oil changes and you should be fine.
1992 318i Coupe parts car
I am Captain Obvious
Old 08-24-2008, 09:47 PM   #4 (permalink)
Car: 2000 bmw 328i
but arent engine flush bad i heard stories of engines breaking down after a week later
Old 08-24-2008, 09:47 PM   #5 (permalink)
Car: 2000 bmw 328i
where can i get that seafoam at???
Old 08-25-2008, 12:10 AM   #6 (permalink)
You can get it at napa auto parts.....
or kragens
While we find your parts, please enter your ZIP Code at PartsAmerica.com
Old 08-25-2008, 01:50 PM   #7 (permalink)
titaniumbullet's Avatar
titaniumbullet is on a distinguished road
Send a message via MSN to titaniumbullet Send a message via Yahoo to titaniumbullet
GET A FLUSH!!! And get your oil changed regularly...
My favorite BMW rims
titaniumbullet is offline   Reply With Quote
Old 08-25-2008, 02:08 PM   #8 (permalink)
done properly, you shouldn't have problems. I think most people forget to read AND follow the instructions - you do get in trouble that way
** DO NOT leave motor flush in your engine for more than 10mins @idle; and never rev an engine that is being flushed.
Flush after all, is using a solvent to melt away the sludge an slop in your engine, it dissolves, mixes in your old engine oil; and is carried away with the oil change.
SEAFOAM like alpine suggests is good as well... it cleans your engine while you drive ;-)
Old 08-25-2008, 05:36 PM   #9 (permalink)
Car: 2000 bmw 328i
thanks for the info guys ill see what happens... does anyone have an repair manual???
Old 08-26-2008, 02:56 AM   #10 (permalink)
Car: BMW Individual2001 E46 325CI manual
sprintman is on a distinguished road
Under no circumstances use a flush. Get yourself some Auto-Rx and a new filter and dino or Group III synthetic and clean it slowly and safely. Google BITOG and it will give you all the info you neeed. Good luck..s
sprintman is offline   Reply With Quote
Old 08-26-2008, 05:15 PM   #11 (permalink)
Car: 2000 bmw 328i
thanks sprintman i going to use dat auto rx and see what happens, but first i have to fix some other lil problems also ...
Old 08-26-2008, 05:45 PM   #12 (permalink)
Just make sure you don't use an oil with Group IV or V basestock and run it hot and hard. You will like the results.
Old 08-26-2008, 06:10 PM   #13 (permalink)
Car: 2000 bmw 328i
Group IV or V basestock??? i dont know what that means can u explain it thanks
Old 08-28-2008, 04:55 AM   #14 (permalink)
Group IV is PAO, Group V is ester (POE). Ask your oil supplier tech line. You want an oil with zero Group IV or Group v for Auto-Rx clean rinse. You need to spend time at BITOG to learn about oils, fuels, additives, etc. Cheers..s Google BITOG
Old 08-28-2008, 12:04 PM   #15 (permalink)
Car: 2000 bmw 328i
aihgt thanks dude that helped alot ill see what happens...
Valve cover e30dream Picture Showroom 4 10-07-2006 10:01 AM
valve cover removal ? j123crx 3-Series (E21, E30) 9 10-05-2005 10:20 PM
95 M3 Valve cover zinger Looking For 0 09-14-2005 07:04 PM
Valve cover hose sp0rky 5-Series (E12,E28, E34, E39, E60) 3 01-19-2004 05:46 PM
New valve cover Euro_325 3-Series (E21, E30) 5 09-30-2003 03:03 PM
