Flat Battery - BMW Forum - BimmerWerkz.com
Old 04-26-2005, 04:34 AM   #1 (permalink)
shakie1973 is an unknown quantity at this point
Hi all,
The problem is i've had a flat battery a few times over the past few months.
Had all the electrics checked,and theres nothing putting a drain on the battery.
But one thing i have noticed is the heaters are just doing what they want.By this i mean,i might have it set on the first setting then all of a sudden it will start blowing really hard,then go back down to where it was.Also when i switch off the ignition sometimes they will start up on their own.This would be enough to drain the battery ( i think )told an auto electrician all this and he said it would be the heater resister switch.
Is that right...............just thought i would check with you guys first.
CHEERS
shakie1973 is offline   Reply With Quote
Old 04-26-2005, 04:38 AM   #2 (permalink)
Howie's Avatar
Howie is an unknown quantity at this point
I used to have flat battery problems because of a faulty after market amplifier which was switching on. It does sound strange that your heaters are doing things when the car is not running. I know for a fact neither of my E46's could use the heaters when off.
Howie is offline   Reply With Quote
Old 04-26-2005, 11:59 AM   #3 (permalink)
you erratic blower speeds is probablly the final stage blower resistor. they are a common problem with alsmot all BMW's that when they go bad the blower motor will take on a mind of it's own. i have never herd of a final stage blower resistor draining the battery but i guess anything is possible. how old is the battery?
Old 04-26-2005, 04:04 PM   #4 (permalink)
[snapback]337891[/snapback]
The battery is 4yr old.....is the final stage blower the same part as this heater resister switch which i was told was the faulty part?
318i-Not charging Hypnogaja 3-Series (E21, E30) 15 10-27-2004 03:18 PM
M5 Flat Battery - How do I get in ? M5 - woaaahhh M-Series (M1, M3, M5, M6) 3 09-23-2004 01:44 AM
Trunk locked with Flat Battery cathylap 3-Series (E21, E30) 7 08-31-2004 01:08 PM
Car battery seems to goi flat....316i H reg JADYO1 3-Series (E21, E30) 1 12-16-2003 02:14 PM
