Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 07-31-2004, 08:16 AM   #1 (permalink)
Photos: 0
tara is an unknown quantity at this point
Hi Guys- I have a 2001 330d and just experieced a faulty climate control.
I press the Cool Air Button on my Automatic Climate Control and lower the temperature down to 17 Degree Celsius and the fan starts to blow air but no cool air is coming out. It worked up to last week.
Can anybody advise? Thanks for your help!
Chris
tara is offline   Reply With Quote
Old 07-31-2004, 12:00 PM   #2 (permalink)
Photos: 0
GRD-4-3L is an unknown quantity at this point
If air is blowing but no cold air, it is definitely due to the following:
1. A/C is low of charge > you have a leak in your A/C system
2. Compressor is not engaging > pressure switch is not trigerring clutch to engage > bad pressure switch (typically on/off only)
3. Burnt out compressor (not likely)
4. Compressor clutch is worn out (not likely on a new car)
5. clogged A/C system > BMW I am quite certain has TXV A/C system, ie. thermal expansion valve with receiver/drier. > cleaning out TXV filter or replacement of TXV typically solves this problem.
6. TXV's temperature sensing bulb has leaked so it is fully closed at all times.
In all above cases, the A/C button should be lighted up. Lighted A/C button does not mean that it is working, it only means electricity is being supplied to compressor clutch.
Quick few things to check
1. Open hood (engine off)
2. Find A/C compressor (from picture of M54 engine, it is at about 7 o'clock position to the engine fan) It is connected to the engine belt, has block rotating component, and should have a large mass (compressor) attached behind it. You know you found it if you can see 2 aluminum tubes coming out of it, one larger than the other.
3. Fire up the engine
4. Engage A/C, put it on full cold but slowest fan speed
5. Quickly run out and watch the compressor clutch. the clutch plate should engage and disengage at regular intervals
The compressor/clutch should cycle on & off at regular intervals at about 10 seconds or so. If it cycles, then you probably have a A/C blockage somewhere. Crap gets trapped in filter (typically just prior to TXV) and block refrigerant path. So no/little refrigerant path, no or little A/C.
If it does not, you could have one or more of the following: bad clutch 'coil', blown fuse, broken electrical circuit, leak in A/C system (most likely). Leak in system is most common. Make sure when the mechanic confirms this, they trace where the leak is occuring. Your car is 2001 so the refrigerant might have leaked out over 3 years but still 3 years is too short. A good A/C system should hold the charge for at least 5 years, 10 if really good.
GRD-4-3L is offline   Reply With Quote
vB code is On
Faulty Climate Control HorthyBoy 3-Series (E46, E90) 50 01-08-2006 01:38 PM
Rebuilding your e36 climate control computer 98e36bostonchic OEM Parts 2 10-18-2005 10:09 AM
Climate Control Rookie 3-Series (E36) 9 03-14-2005 12:51 PM
Climate Control Board - Faulty or Not bbasra 3-Series (E36) 4 08-08-2004 12:52 PM
BMW has perhaps the WORST climate control SpeedsterBMW 3-Series (E46, E90) 20 07-22-2003 11:44 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
