Remove the fan and clutch assembly. Start the engine and check if the shaft has a wobble in it. Stop the engine and check the shaft for any play. It could be that the water pump bearings are on the way out and putting strain on everything else as a result. Another option could be to look at an electric fan instead.
Have a look at the options available through
Zionsville Autosport
