EZ Chill R-134a refill - BMW Forum - BimmerWerkz.com
Old 07-24-2009, 09:57 PM   #1 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
I just bought one of these from wal-mart:
EZ Chill.
I hooked it up to the low pressure port and it said the psi was around 40. I tried topping it off and after holding the button down the pressure only got lower and lower. Now the pressure is around 35.
Was I just doing it wrong or do these not work?
Thanks!
yammahamma is offline   Reply With Quote
Old 07-24-2009, 11:18 PM   #2 (permalink)
Car: 1994 e34 525
coolvegase34 is an unknown quantity at this point
Don't worry about the guage. Turn on the car. Turn on the ac and put it on the full setting. Hook up the hose and continually shake the can until it is empty. Wear gloves because the can will get very cold. Afterwards, drive the car with the air on and it should work. Are you sure that you have a car the takes r134a? If it is pre-1994 it will use freon.
coolvegase34 is offline   Reply With Quote
Old 07-25-2009, 03:05 AM   #3 (permalink)
yammahamma's Avatar
Car: '01 330i
It's for sure 134, I don't want to over fill it either I've heard that's bad.
Old 07-25-2009, 04:46 AM   #4 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
You are seriously better of going to an air-con service station, as they take out all the old stuff, then the system is cleaned and re-filled with r134a & oil, leak tested and pressure tested.
Here in the UK, you can buy the same can as you have for £38.00 or go to a service station and get it done properly for £45.00. So for an extra £7.00 its worth it.
Old 07-25-2009, 06:15 PM   #5 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
To Bad no one will touch it I said no leak sealer.... Leaksealer = replace whole system before anyone will touch it.... Unless you have the proper training you shouldn't touch the A/C system..... Yes the pressure dropping on th LOW side is good..... The Higher you can get the Highside and the lower you can get the low side the better the lowside should be 25-35 psi and the high side should be 200+psi.
1992 318i Coupe parts car
I am Captain Obvious
Old 07-25-2009, 06:19 PM   #6 (permalink)
Ummmm No... you will blow the compressor, one of the high side lines or condensor up.... pre-1994 = R-12
Power Steering Fluid? Refill to line? or Flush and Replace? Delmarco 3-Series (E36) 9 05-02-2008 07:43 PM
Refill AC HELP!!! Redbullrr 3-Series (E36) 21 05-24-2006 08:31 AM
R-134a Conversion bkcraun 3-Series (E36) 5 01-10-2005 07:46 AM
520I SE Auto Gear Box Oil Refill? Ragamuffin Brian 5-Series (E12,E28, E34, E39, E60) 0 04-11-2004 07:11 AM
