Engine Flooded - BMW Forum - BimmerWerkz.com
post #1 of 6 (permalink) Old 12-29-2004, 06:33 AM Thread Starter
drdave is an unknown quantity at this point
My wife owns a 2000 323CI. This past Saturday her car would not start. It started for a brief moment at first, then died. From then on it would turn over but not start. It sat until Monday waiting for a tow to the dealer. It still would not start on Monday.
The service department told her that the engine was flooded. How this happens on a fuel injected engine puzzles me. She does NOT press the accelerator pedal when starting.
Can someone tell me how this happens and what can be done to alleviate if it happens again? The service department said (I didn't talk to them) that they drained something and the car has been fine since yesterday. If it is as simple as draining the fuel rails or something similar, I can do that myself?
Thanks. Dave
2000 323CI (wife), 2004 MINI Cooper S (mine)
drdave is offline
post #2 of 6 (permalink) Old 12-30-2004, 04:18 PM
geo123 is an unknown quantity at this point
i get this on mine if i start in a cold morning and only move it a couple of yards like taking out the drive before i take the van to work
when i get in and start it its very rough and its just cause its slightly flooded
when i take the car out now i run it around the block before i park up
geo123 is offline
post #3 of 6 (permalink) Old 12-30-2004, 04:55 PM
this should never happen. the onyl way i can think is that the injector opening valves (controlled electromagnetically) are failing. hence, gas leaks into the cylinder. i imagine that if this is the cause, it will happen with regularity. otherwise no clue what they are talking about (flooded??? )
peterkulesza is offline
post #4 of 6 (permalink) Old 12-30-2004, 05:52 PM
Vin
Vin is an unknown quantity at this point
Ive heard of this problem on quite a few 2000 vehicles M52 and M54 engines. Just try not to start it and turn it off quickly, let it run for a few mins b4 turning off, bmw technician once said jus minor ecu malfunction
Vin is offline
post #5 of 6 (permalink) Old 12-31-2004, 08:15 AM Thread Starter
Thanks for the replies.
I believe that is what happened. The day before, my wife just moved the car into the garage and it only took a couple of seconds. The engine did not run very long before she shut it off.
As for my other question, how do you alleviate the flooded engine?
drdave is offline
post #6 of 6 (permalink) Old 12-31-2004, 10:28 AM
Renwaldo is an unknown quantity at this point
Hi,
I had a problem with my BMW e46 '99 318i. It wouldn't start so I pressed teh accelerator down and it flooded. Hda to remove spark plugs, clean the fuel off them and put them back in. Worked fine.
Renwaldo is offline
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-10-2006 11:56 PM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
