EML and ASC light stay on car is dead??? - BMW Forum - BimmerWerkz.com
Old 05-16-2011, 08:21 AM   #1 (permalink)
Deon323i is on a distinguished road
HELP HELP HELP
I have a E46 323I 2000 model, the eml and the asc light stay on and the car does not pick up more than 2200rpm, had it pluged in and the dude told me that it was the Throttle body, so I got a new one put it in and the same happend, reset the car start it its fine, a view on off's and it did the same, I checked the wireing its fine, took it back pluged it in again and it gave allot of errors nl: 169 engin throttle output stage shutoff after diagn. error, 172 signal pedal travel sensor p1542 : p0220, 8 signal air mass flow sensor p0101, ens. so i took the throttle cable out and lube it good and the pedal and install it again, still it goes and the after a view starts it does the same. Even changed the air filter, disconected the battery for 10 min, even pushed the pedel to the floor for 2 min in the on position of the ignition but still it goes for a wile and then after a view starts it does the same,, PLEASE HELP ME!!!
Deon323i is offline   Reply With Quote
Old 05-16-2011, 02:12 PM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Unfortunately, you didn't need to CHANGE the throttle body, just clean it!
Like everything else too!
Is it using "More" fuel? Fuel filter/injectors/throttle sensor...
Does it try to stall? Idle control valve/cam sensor/throttle sensor...
Some of the errors may be a direct result of randomly unplugging modules...
Start the car then unplug the modules one by one 'til she stops! Then leave her for quite a while... Disconnect battery too !
This method is NOT advised by BMW, BTW !
Get back with any results...
DAZ
Brake Light and Traction Light stay on Help! KingZeus 3-Series (E46, E90) 0 04-30-2011 09:27 AM
hey my traction and parking brake light stay on fontaiedmo 3-Series (E46, E90) 0 03-12-2011 02:21 AM
Parking brake and traction light stay on fontaiedmo 3-Series (E46, E90) 0 03-06-2011 01:05 PM
ABS, DSC, and Brake light stay on.... cub_fever 3-Series (E46, E90) 0 09-04-2007 01:01 PM
clock led light dead... maxslomoff 3-Series (E36) 4 11-27-2005 03:28 PM
