Electrical Problems... - BMW Forum - BimmerWerkz.com
Old 06-10-2005, 06:23 PM   #1 (permalink)
Damnit is an unknown quantity at this point
hey, iv got a 99 323i and its got some electrical problems... ghead if u do "good shifts" (smooth shifts) the car will sometimes start on its first try...but still even sometimes the car wont even crank on the first try the first pic is when the key is in the first position, when only the radio is on...when that doesnt turn on in the first position the car doesnt start. if it doesnt turn on there, it turns on along with the rest of the panel in the second position. )pic shown( then the last pic is when the key is in the first position and that turns on like normal then the car starts like normal as well. anyone know what the problem is? im thinking of reseting the ecu but im not sure, will reseting cause any damage even if it is not the problem? ty
Electrical Problems...-dsc02946.jpg   Electrical Problems...-dsc02947.jpg   Electrical Problems...-dsc02948.jpg
Damnit is offline   Reply With Quote
Old 06-12-2005, 10:37 PM   #2 (permalink)
^ please guys i still need some light shed on this
Old 06-12-2005, 10:50 PM   #3 (permalink)
zibby's Avatar
Car: yes
[snapback]353050[/snapback]
The way you describe the symptoms is a very enigmatic to me(English is my second tounge ), but it looks to me like an ignition switch problem assuming that starter and battery is in good condition.
http://www.q8oils.it/
Old 06-13-2005, 06:09 AM   #4 (permalink)
english is my third, and i have the same problem..... used
maybe it is your post
what is this first or second position???
Old 06-13-2005, 11:47 PM   #5 (permalink)
BMWLotAttendant's Avatar
BMWLotAttendant is an unknown quantity at this point
Send a message via AIM to BMWLotAttendant Send a message via MSN to BMWLotAttendant
Did you try hitting the gas when turning on the car?
BMWLotAttendant is offline   Reply With Quote
Old 06-14-2005, 02:03 PM   #6 (permalink)
Originally posted by zibby+Jun 12 2005, 09:50 PM--><div class='quotetop'>QUOTE(zibby @ Jun 12 2005, 09:50 PM)</div><div class='quotemain'>The way you describe the symptoms is a very enigmatic to me(English is my second tounge ), but it looks to me like an ignition switch problem assuming that starter and battery is in good condition.
[snapback]353055[/snapback]
[/b]
ok ty, il look into that. wat is wrong with the post that u dont understand? go to start car, it sometimes doesnt...
[snapback]353126[/snapback]
once again, what is wrong with the post? the first position is when u have the key in the ignition and u turn the key once "position 1" turn it twice "position 2" etc
<!--QuoteBegin-BMWLotAttendant
@Jun 13 2005, 10:47 PM
[snapback]353387[/snapback]
[/quote]
it is an electrical problem, the engine turns over just fine if all of the electrical crap is in order
someone told me it may b faulty relays...and ill look into the ignition switch ty
Electrical Problems Duge 3-Series (E36) 12 04-30-2005 05:41 PM
Electrical Problems And Other Newbie Questions 325eXTATIC 3-Series (E21, E30) 4 03-31-2005 09:35 AM
My Electrical Problems e30_325i 3-Series (E21, E30) 4 03-06-2005 09:44 PM
Electrical Problems lulul 3-Series (E36) 4 01-11-2005 03:52 PM
Electrical Problems Edrandall79 3-Series (E21, E30) 4 05-31-2004 11:41 AM
