Electrical Problem? - BMW Forum - BimmerWerkz.com
Old 08-07-2003, 10:07 AM   #1 (permalink)
akrauss is an unknown quantity at this point
Thumbs up
It seems I am replacing one bulb or another (headlight, brakelight, turn signal, etc.) every couple of months. First my local mechanic gave me some mumbo jumbo about the bulbs being high output and didnt think it was an electrical problem (I have a 1999 323i- no xenon lights). Now after seeing me burn thru a few, he agrees there's a problem. I have an appt. with BMW on monday and am concerned its going to cost me hundreds in labor. They said that despite all the new computer diagnostics, they still troubleshoot electrical problems pretty much as they did 10 years ago. First, what is the normal life expectancy of these bulbs in hours/days,etc.? Second, is anyone aware of this being a common problem? Third, what can I do to make sure I dont get taken for a ride (no pun intended) by the bimmer dealer? Any advice would be most appreciated.
akrauss is offline   Reply With Quote
Old 08-07-2003, 10:18 AM   #2 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
Not sure on the specifics to your questions, however, when you replace the bulbs are you using aftermarket bublbs or the ones rated (by wattage, etc) for your car? If they are the OE rated bulbs then chances are you have a short somewhere. Are any of the fuses blowing?
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 08-07-2003, 11:15 AM   #3 (permalink)
I dont know about the wattage, but I assume my mechanic could get that right. I will check however. I dont think any fuses were found to be blown, because I checked on at least one instance and I didnt see anything on my mechanics bill for replacement (I believe he also would have mentioned that to me.) Thanks.
Old 08-07-2003, 11:16 AM   #4 (permalink)
Old 08-07-2003, 05:54 PM   #5 (permalink)
Guess: voltage regulator. your alternator puts out about 16 volts max at high rpm. fully charged battery is 14.2 volts. the system runs on 12 volts, which is usually what the bulbs see (given resistive losses).
have the mechanic run a check on the voltage regulator; also there may be codes (remeber these codes go away from the memory after a certain amount of start/stop cycles).
peter
Old 08-07-2003, 05:56 PM   #6 (permalink)
i forget:
you ALWAYS get taken if you let them diagnose the problem. once diagnosed correctly, they often can fix it in a reasonable manner.
peter
Old 08-07-2003, 10:25 PM   #7 (permalink)
EXtech's Avatar
akrauss: peter has a very good point. It sounds like the alternator *could* be peaking a little high thus blowing the bulbs. There are several other possibilities if it were just blowing brake light bulbs, but you're having problems with bulbs all over. Have your technician do a bulletin search, if I remember correctly there was a bulletin on diode replacement within the alternator as well as a possible complete replacement. I cannot remember for sure as it has been some time since I've combed those bulletins. This might not be the culprit but it's a place to start (simple charging system test). If it does turn out to be something simple, after the tech diagnoses it then fix it yourself. That might piss him off but it's your money. Don't fret, it shouldn't be too bad.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 08-08-2003, 03:54 PM   #8 (permalink)
Thanks a bunch for all your thoughts. I really do appreciate it. Two follow-ups: 1) How long should these bulbs be lasting (months, years, etc.)? and 2) assuming it is the alternator/voltage regulator, what's the damage $$$$$?
Old 08-08-2003, 03:59 PM   #9 (permalink)
ex owner/admin
Furious's Avatar
what kinda bulbs are they? secondly if they are aftermarket bluish ones they can last anywhere from a few months (yes a few months) to a year and a bit, mine usually last around a year and 3months (on average and also i have constant low beams on) stock ones last longer,
Old 08-08-2003, 06:01 PM   #10 (permalink)
EXtech's Avatar
with the proper bulbs, they could last several months to a year plus. If there is an alternator problem, the only damage would be the alternator itself and the blown bulbs. When a charging system test is done, the battery will be checked also. This would be the only other place damage could be. If there were any control modules damaged then they would either no longer be working or a fault code will show up.
good luck!!
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
Old 08-08-2003, 06:10 PM   #11 (permalink)
Thanks, I'll let you know how it turns out on Monday.
Old 08-08-2003, 10:09 PM   #12 (permalink)
extech is right. bulbs last many months to years.
i have no clue if the entire alternator needs to be replaced (likely; they have internal regulators and these days people just replace entire modules as opposed to figuring things out... fuck, i am an old fart...).
is the car still on warranty ? (you may be able to claim extended warranty if the problem first showed up in warranty period, eventhough the car is too old now..)
peter
Old 08-09-2003, 12:23 AM   #13 (permalink)
BlackTape's Avatar
BlackTape is an unknown quantity at this point
Send a message via ICQ to BlackTape Send a message via AIM to BlackTape Send a message via MSN to BlackTape Send a message via Yahoo to BlackTape
isn't it cheaper to just keep replacing bulbs then the labor to fix a huge electrical problem
<img src='http://www.satchmo.com/cashmoney/btymers.jpg' border='0' alt='user posted image' />
<span style='font-family:Impact'><span style='font-size:21pt;line-height:100%'><span style='color:red'> GANGSTA Tape</span></span></span>
BlackTape is offline   Reply With Quote
Old 08-09-2003, 06:45 AM   #14 (permalink)
ex owner/admin
Furious's Avatar
not really, besides its the hastle
Old 08-11-2003, 03:43 PM   #15 (permalink)
Dropped the 1999 bimmer in question off this morning and just spoke to service. Said they found one (or more?) sockets with corrosion causing a short and (as suggested by "GreenDragon") the blown rear brake light was due to installation of aftermarket buld with incorrect wattage (My local mechanic will be hearing from me !). Total bill, incl. oil change (synthetic) was $190.00. Thanks again for all your help.
Electrical Problem With 2002 323i jisang1 3-Series (E46, E90) 4 02-01-2005 01:13 PM
Need The Experts-mysterious Electrical Problem??? JonnyM3 3-Series (E36) 6 12-06-2004 07:04 PM
strange electrical problem diadpaku 5-Series (E12,E28, E34, E39, E60) 7 11-09-2004 06:19 PM
Electrical problem DC118us 3-Series (E21, E30) 2 07-05-2004 09:40 PM
