Hi All, been a while since I've posted in here, FINNALY done with this semester.
Here's my newest problem:
A few days ago, here in NJ, the temp dropped sharply to 4 degF. I got to my car, scrapped off the ice and got it, started her up. The hazards were tripped and they didn't want to go off. Thinking that it would diminish as the engine warmed everything up which they did, I didn't pay to much attention to it.
Then I noticed that reguardless of the power being on or off, everytime I open the two front doors (not rear), the windows open about 1/4 in, then when I close the doors, they as well close.
Some of you may remember that I have NO ALARM SYSTEM in my car. I also have never had anyone re-program the ECU to show a fake system. With that said, try to explain this: When the doors are locked, the clown nose blinks... continuously until unlocked. ... looks cool, but it shouldn't be happening.
Now... I was reading in the E46fanatics forum about problems with model year's 99-00 where upon inital starting of the car in cold weather, the rpm's will dip quickly then regain the higher rpm. This would happen continuously until the engine is warm. I read that this was due to the faulty $1500 VANOS system part that most if not all early E46's will encounter.
Is there a connection to the above symptoms? Anyone posted something like this a while back? I tried a search, but didn't get something like this.
So what's going on? How do I fix these glitches... meaning, kill those damn gremlins!!!
btw, I'm due in a few hundred miles for an Inspection II.... anyone recommend a NJ area dealer?
Thanks
Dough
__________________ <img src='http://img.photobucket.com/albums/v298/doughboyea/car3.jpg' border='0' alt='user posted image' />
<span style='color:green'><u>Proud</u> Member of the BMW Community</span>
<span style='color:black'>1999 BMW 328i Jet Black --Total Dinan Points: 5 --
<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a>Dinan Stage 1 Suspension<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a></span>
<span style='color:black'><a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a>K&N Air Filter<a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a></span>
there is a software update for 330, issued about 4 months ago or so. it may solve the wondering idle for you, have them load it at inspectionII. takes about 45 mins to load...
Have'nt had that problem on my car, but as far as the window problem, you can check your manual and it might be that somehow your car has adjusted itself that way, it's an easy fix. Usually, manually with a special tool, you can adjust the way you want the window to set by removing the side door molding, there's a hole there where the tool goes in and the adjuster's are in there. Might want to be patiant with that, I already broke a window. As for the hazard's, I have no idea but usually with that type of thing happening check your fuse. If not one of your bulbs may be causing a ground fault....
Forgot to tell you, that the door window's are set up that way for an airtight seal. When you unlock, the windows roll down so they don't hit the molding right above, then when you close the door the windows roll back up for an airtight cabin. It's automatic.. If they don't roll down, on opening the door, the window will hit that molding, and may cause damage.
Originally posted by joeyoung@Jan 5 2005, 04:06 PM Forgot to tell you, that the door window's are set up that way for an airtight seal. When you unlock, the windows roll down so they don't hit the molding right above, then when you close the door the windows roll back up for an airtight cabin. It's automatic.. If they don't roll down, on opening the door, the window will hit that molding, and may cause damage.
[snapback]264886[/snapback]
Well if it's automatic, then why is it only starting now, after the vehicle had reached 5 years of age? And I thought that only happened on convertables, I have a Sedan.
Dough
It's official, she thought she was a coupe. How, I do not know. The dealer said that she would need a reprograming of the "DME" at $102.82 to correct the problem. He noticed that the fault codes comming up indicated that it was never programed to act in a Sedan. So he said, guessing that is, that she had her computer replaced at some time with out being programed correctly. He couldnt' check the actual computer, as it was buried deep in the dash, to confirm this.
Dough
btw, Insepection II charge was at $451.91 at Hunterdon BMW, in Lebanon, NJ. Cheapest around. Look here for the results.
