Easy question? - red light on dashboard! - BMW Forum - BimmerWerkz.com
Old 05-03-2004, 11:02 AM   #1 (permalink)
mike-france is an unknown quantity at this point
I just bought a 2001 320d but don't have the user manual and am somewhat concerned by a red light that has just appeared on the dash!
On the left hand side of the main display there is an outline picture of a car that normally indicates if the boot or one of the doors is open. Just to the top left of this there now appears a red picture of a headlamp.
Any ideas?!!
Thanks,
Mike
mike-france is offline   Reply With Quote
Old 05-03-2004, 11:07 AM   #2 (permalink)
mankiks323i's Avatar
mankiks323i is an unknown quantity at this point
its telling you have a bulb burned out check all bulbs on that side were the light is lit up once you find the bulb replace it with the same wattage and problem should be solved
"What happens here stays here" Las Vegas
mankiks323i is offline   Reply With Quote
Old 05-03-2004, 11:34 AM   #3 (permalink)
EcianIce is an unknown quantity at this point
Send a message via AIM to EcianIce Send a message via Yahoo to EcianIce
correct. i just had that problem with my right front blinker light. replaced it and the warning light went away.
<img src='http://www.bmw-forums.com/forum/uploads/post-46-1095116979.jpg' border='0' alt='user posted image' />
got skaw?
<span style='font-size:14pt;line-height:100%'><a href='http://www.unitedbimmer.com' target='_blank'>unitedbimmer.com</a> - By the members, for the members!</span>
EcianIce is offline   Reply With Quote
Old 05-04-2004, 03:07 AM   #4 (permalink)
Thanks guys - found the offending light! I now just need to work out how to change it without resorting to my local rip-off garage
Old 05-04-2004, 10:01 AM   #5 (permalink)
Mach 5's Avatar
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
Which light went out? We might be able to help.
Ben
&quot;It's not because I'm an aggressive driver, it's because I'm an idiot&quot; actual quote from my wife.
Mach 5 is offline   Reply With Quote
Old 05-04-2004, 10:54 AM   #6 (permalink)
It's the front right dipped light - i.e. the side lights work and the main-beam works, it's the mid-range one that's gone on that side.
What I guess would be really good is (a) a good online store where I can buy the bulb at a reasonable price and (B) a pointer to a tutorial or similar with step-by-step instructions for changing it.
By the way, a bit of background on me - after around 10 years of deliberating whether it was worth the money or not, a few weeks ago I finally plucked up the courage to buy my first BMW - and I am thrilled with it
...why I waited so long I'll never know, but I think I'm hooked for life already...
(note: front right means nearside for me as it's a French car)
Old 05-04-2004, 01:46 PM   #7 (permalink)
not exactly sure but if its the high beam the socket should be reachable by hand twist off and remove bulb. If its the side light turn signal blinker you need to open hood then insert flat head screw drive in the fender there should be a hole there push down then the light assembly will come out. try your local auto part store first.
&quot;What happens here stays here&quot; Las Vegas
Another Airbag Light Question storme 3-Series (E46, E90) 8 11-21-2005 01:01 PM
Really dumb light replacement question Trob 3-Series (E36) 3 10-02-2005 10:29 AM
'94 318is: brake light & fog light question ultraviolet353 3-Series (E36) 2 08-14-2004 01:46 AM
Alarm & Brake Warning Light question K2Jones 3-Series (E46, E90) 9 02-24-2004 05:32 PM
