E90 key or Ignition problem - BMW Forum - BimmerWerkz.com
Old 04-06-2011, 12:25 PM   #1 (permalink)
kuffkat is on a distinguished road
Cool E90 key or Ignition problem
Have a 2006 318d se, had a bang to the front a while back deploying airbags.
Have since repaired vehilce, replaced airbags and modules and sensors but also lost the key in the process.
Ordered a new bladeless programmed key from the dealer.
Now when i try to insert the key into the slot the slot just keeps rejecting it out, it will not click into the space and stay.......
No idea why, can anybody please help????
kuffkat is offline   Reply With Quote
Old 04-06-2011, 05:35 PM   #2 (permalink)
WABMWTECH is on a distinguished road
you need to have at least one valid key to enable a new one, since you dont have one you will need to order a new CAS and programmed key kit
WABMWTECH is offline   Reply With Quote
Old 04-07-2011, 01:52 AM   #3 (permalink)
was a new key and programmed from the dealer, any other ideas?
Old 04-07-2011, 08:39 AM   #4 (permalink)
I know it was programmed from the factory because it is vin coded, regardless your gonna have to get a new CAS and key set non comfort access cars can have 4 keys enabled at a time what is probably going on is you only have the first two keys enabled and keys 3-10 disabled the can only be changed with a gt1 or ista/D but still you need to have at least one of the original keys so a new one can be enabled and if the car has comfort access oonly two can be enabled at a time
Ignition Problem hunter325i 3-Series (E36) 5 04-12-2007 10:00 PM
Ignition Problem? thekid 3-Series (E36) 3 03-31-2005 10:59 AM
Ignition Problem PokerPrincess325i 3-Series (E36) 26 08-28-2004 02:11 AM
ignition problem....... please help Rich328 3-Series (E36) 6 06-09-2004 07:36 AM
ignition problem....... please help ctx66 Bimmer Talk/Motorsports Talk 0 12-31-1969 07:00 PM
