E46 Tire Wear - BMW Forum - BimmerWerkz.com
Old 02-24-2005, 03:22 PM   #1 (permalink)
clarkinc is an unknown quantity at this point
Hey guys, has anyone witnessed excessive tire wear on both the rear tires? My 3er is equiped with factory sport suspension and the tires are incurring sharp wear on the inside at about a 45 degree angle. Ive had an alignment done three times... the first time by an after market tire shop the next two by the dealer. Still the same effect.
I have heard this could be the shocks but have also heard it could be something in the suspension bent. Can anyone help?
Greg 99 323i
clarkinc is offline   Reply With Quote
Old 02-24-2005, 03:44 PM   #2 (permalink)
it could be something bent but i doubt it since both are wearing, and an alignment wouldnt help you since its in the rear, and you dont align the rear. yes shocks will have that affect, wore out springs will affect the camber more-so than the shocks, shocks dont usually affect the camber too much
Old 02-24-2005, 05:45 PM   #3 (permalink)
doughboyea's Avatar
doughboyea is an unknown quantity at this point
Send a message via AIM to doughboyea Send a message via Yahoo to doughboyea
^ What he said, but I would like to add that it could just be the tires. Being that our cars are rear wheel drive, there will be more force applied to them, hence, making them more susceptible to wear. On my 328i, I've got snow tires. The ones in the front still have PLENTY of tread left, however, the rears are bare right in the middle. I'm assuming by centrifical force as I do alot of highway driving. Just something to think about.
Dough
<img src='http://img.photobucket.com/albums/v298/doughboyea/car3.jpg' border='0' alt='user posted image' />
<span style='color:green'><u>Proud</u> Member of the BMW Community</span>
<span style='color:black'>1999 BMW 328i Jet Black
--Total Dinan Points: 5 --
<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a>Dinan Stage 1 Suspension<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a></span>
<span style='color:black'><a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a>K&amp;N Air Filter<a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a></span>
doughboyea is offline   Reply With Quote
Old 02-24-2005, 05:48 PM   #4 (permalink)
true, but you prolly had too much air in the rears to begin with, you do make sense though. A 45 degree angle is a little extreme to be just the tires
Old 02-24-2005, 09:00 PM   #5 (permalink)
Yea I went through at least three sets (moving the front to the back). It has to be something besides the tires, I don't think the sport suspension could be doing it alone. Thanks for the input.
Old 02-24-2005, 09:35 PM   #6 (permalink)
doughboyea's Avatar
[snapback]298680[/snapback]
Good point... I kinda missed that.
Old 03-03-2005, 12:26 AM   #7 (permalink)
Originally posted by doughboyea+Feb 24 2005, 09:35 PM--><div class='quotetop'>QUOTE(doughboyea @ Feb 24 2005, 09:35 PM)</div><div class='quotemain'><!--QuoteBegin-e30fanm3@Feb 24 2005, 06:48 PM
[snapback]298886[/snapback]
[/b][/quote]
Thanks alot guys...Youve been a big help in searching for the problem.
Any of you guys think it could be the bearings and or hub causing this?
Old 03-03-2005, 04:07 PM   #8 (permalink)
no, you would hear that
Old 03-26-2005, 07:11 PM   #9 (permalink)
lms20fan is an unknown quantity at this point
I have been fighting with my dealer about this problem...my '02 330ci with sport package is on its 3rd set of rear tires, all because of the right rear wearing to the threads on the inside of the tire...I PAID for an alignment after the first right rear wore out and replaced with two new rears...and after 15k on the new ones, same thing happened. I've read where it might be camber? And i have to buy a camber kit?? Is this true?
lms20fan is offline   Reply With Quote
Old 03-26-2005, 07:36 PM   #10 (permalink)
amutti is an unknown quantity at this point
Originally posted by lms20fan@Mar 26 2005, 08:11 PM
I have been fighting with my dealer about this problem...my '02 330ci with sport package is on its 3rd set of rear tires, all because of the right rear wearing to the threads on the inside of the tire...I PAID for an alignment after the first right rear wore out and replaced with two new rears...and after 15k on the new ones, same thing happened.* I've read where it might be camber?* And i have to buy a camber kit??* Is this true?
[snapback]319050[/snapback]
Doesn't the sport suspension have -0.5 degree camber. This would cause more wear. I just can't remember if it is on the inside or the outside?
amutti is offline   Reply With Quote
Old 03-27-2005, 01:09 PM   #11 (permalink)
it would be on the inside but i dont think the sport suspension has any more camber, and you wasted your money on the alignment cause that has nothing to do with the rear tires
Old 03-27-2005, 06:57 PM   #12 (permalink)
[snapback]319451[/snapback]
The second time I went in the dealer said it was the alignment again and wanted me to pay for it AGAIN...which I did not. Anyone have any guesses what the problem is then?
Old 03-28-2005, 12:25 AM   #13 (permalink)
Moderator
Dirty_Tool's Avatar
[snapback]298576[/snapback]
E46 rear suspension is adjustable so you DO align the rear. Just thought I'd mention this.
DT
DT
Old 03-28-2005, 04:44 PM   #14 (permalink)
adjustable camber or toe?
Old 03-29-2005, 10:44 PM   #15 (permalink)
Originally posted by lms20fan+Mar 27 2005, 06:57 PM--><div class='quotetop'>QUOTE(lms20fan @ Mar 27 2005, 06:57 PM)</div><div class='quotemain'><!--QuoteBegin-e30fanm3@Mar 27 2005, 03:09 PM
[snapback]319645[/snapback]
[/b][/quote]
Where are you located? I believe if enough guys gang up one one dealer they would have to at least look for a solution. Maybe we're too scattered to make a real differance.
Tire Wear and Alignment Dave-T 3-Series (E46, E90) 1 09-08-2005 12:46 PM
1998 540i Rear Tire Wear Tom C 5-Series (E12,E28, E34, E39, E60) 7 11-12-2004 09:24 AM
Unbelievable rear tire wear cpadpl 3-Series (E46, E90) 3 06-28-2004 06:47 AM
Excesive tire wear '01 530i 5-Series (E12,E28, E34, E39, E60) 4 03-19-2004 12:45 PM
Lowering Springs and Tire Wear? grecobeemer 5-Series (E12,E28, E34, E39, E60) 4 01-16-2004 06:00 PM
