E46 - Idling Problem - BMW Forum - BimmerWerkz.com
Old 11-10-2005, 10:50 AM   #1 (permalink)
Richard Lowe is on a distinguished road
Unhappy E46 - Idling Problem
Hi - I have a 318i. When I take my foot of the accelerator, the revs drop easily to about 1200 then rise slightly and then over about 5 seconds, slowly drop down to where it should be at about 800. Has anyone any idea what the cause might be?
Cheers
Richard
Richard Lowe is offline   Reply With Quote
Old 11-10-2005, 12:41 PM   #2 (permalink)
storme's Avatar
storme is an unknown quantity at this point
check for an air leak around the air filter and relevant pipes
use some washing liquid smeared around the outside of the varoius air pipes....any bubbles will show u where any leak is
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Old 11-10-2005, 12:43 PM   #3 (permalink)
EXtech's Avatar
I would start with looking for a vacuum leak, it's the easiest, simplest and cheapest place to start. This could be anything from a loose intake boot at the throttle body to a leaking vacuum hose under the intake or even a failing crank case vent valve.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 11-11-2005, 11:08 AM   #4 (permalink)
storme's Avatar
erm,,,didnt i say that???
Old 11-11-2005, 02:41 PM   #5 (permalink)
EXtech's Avatar
yeah you did. At the time I was typing the reply, you hadn't posted.. nobody had. We were replying at the same time... look at the time stamp
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
Old 11-12-2005, 01:31 AM   #6 (permalink)
storme's Avatar
at least we are on the same level
too many ppl on this forum will say the worst case scenario ....
extech is right...look for the easy option 1st...if not come back and we will start again
sry extech
Stick Shift Problem, Transmission ilDawg M-Series (M1, M3, M5, M6) 0 09-16-2005 08:10 PM
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 0 02-28-2005 07:33 AM
Shorting in a fuse for guages, and other idling. M5power 5-Series (E12,E28, E34, E39, E60) 0 04-10-2004 11:35 PM
Strange idling problem. Batunas 5-Series (E12,E28, E34, E39, E60) 4 12-17-2003 11:56 AM
