E46 Fuel Tank Pressure Valve R&R - BMW Forum - BimmerWerkz.com
Old 07-05-2011, 03:47 PM   #1 (permalink)
Car: 2003 325xi
sevenmalards is on a distinguished road
Hi, I have an 03 325xi and need to replace the fuel tank pressure valve. its under the intake manifold at the front of the engine, behind the power steering reservoir. Has anyone changed this? Have any "easy" ways of getting to it without relocating the power steering? Thanks.
sevenmalards is offline   Reply With Quote
Old 07-05-2011, 04:22 PM   #2 (permalink)
Car: 2003 325xi
I've got the new fuel tank pressure valve installed. The only item required to move is the air filter housing. Remove the two 10mm bolts, loosen the hose clamp at the air flow sensor, disconnect the electrical for the air flow sensor, and the entire air filter housing will lift out. There is another wiring harness below the air sensor, just remove the grommet and set aside. With the air box out of the way the fuel tank pressure valve is front and center. It was a really easy exchange.
Can low oil pressure from valve cover create an engine knock??? JohnU 1,6,7,8 - Series and Mini Cooper 7 02-08-2010 01:10 PM
Excessive pressure in gas tank & gas odor bobzbeemer95 5-Series (E12,E28, E34, E39, E60) 18 10-07-2009 02:56 AM
94 540i- Blowing fluid out High pressure relief valve 94-540i 5-Series (E12,E28, E34, E39, E60) 1 07-02-2009 08:36 AM
Ventilation Valve Pressure Regulating Valve /Oil Separator jaguar52662 5-Series (E12,E28, E34, E39, E60) 2 02-02-2009 09:03 PM
Fuel Leaking!!(Fuel tank) chungaa1 1,6,7,8 - Series and Mini Cooper 5 08-10-2004 05:02 PM
