| e46 330i overheating problem Hi all members. As a new member I wonder if anyone can help me sort out the overheating problem with my 2000 330i.
I have replaced the water pump, thermostat, temp sensor, fan relay, and expansion tank cap. I have bled the system but after running for about 15 mins the engine starts overheating on the right (facing the car) but the pipe on the left is only warm, and the fan does not kick in. The temp gauge shows normal. On turning the ignition on initially there is a distinct click from the dash in the area of the radio. This "click" has never been there before! Is it possible that the electric fan has packed up? The car has done 283,000km, and this is the first repairs I have had to do. All advice will be appreciated. |
