| E46 328 ci se braking problem - help please? I know its a common thing for the abs light and traction control light to come on the dash however on my car (99 model) when braking it feels like abs is kicking in even when its dry on the road as the pedal judders and bounces back and you can hear what sounds to be a pump working somewhere on the car, then other times you drive and brake and it appears to be normal? is this a common fault or someone know what the problem is? either the sensors need cleaning/replacing?
help would be greatful
thanks |
