E46 323i fuel trim P1188 and P1189 - BMW Forum - BimmerWerkz.com
Old 03-06-2011, 05:08 PM   #1 (permalink)
Car: 1994 325Ci (Cabriolet)
bavareze is on a distinguished road
Send a message via Yahoo to bavareze Send a message via Skype™ to bavareze
Hello,
So ever since I got this 323i with 170k I had these two codes, plus other related codes like P0170, P0173, P0150. Car runs fine.
Reading the forum I learned this might be caused by faulty O2 sensors. So today I went to Autozone and purchased two Bosch Premium 13466 sensors. After installation, nothing really changed.
I looked into Live Data section with my scanner and I found out these figures:
I let the car idle and the values slowly go to:
STFT B1 27.3% and stays there, I assume it is maximum
O2S B1 0.035 V
STFT B2 27.3%
O2S B2 0.035
it idles just fine like this for about one minute, then changes by itself to:
STFT B1 0 (zero)
o2S B1 0.025 V
STFT B2 0 (zero)
o2s B2 0.025 V
Any help would be highly appreciated!
bavareze is offline   Reply With Quote
Old 03-21-2011, 07:44 PM   #2 (permalink)
bmwtech1 is on a distinguished road
Looks like by the 27% that the dme is trying to add fuel to compensate for a lean mixture, if it was negative it would be trying to take it away. More than likely you have a vacuum leak. I would check the black intake boot, both sections are know for splitting but the more common one is the one that connects to the throttle and idle valve, it usually rips at the little elbow that goes to the idle valve, if you can't see it reach your hand in there to the backside of that elbow and you will probably be able to put your finger right in there.
bmwtech1 is offline   Reply With Quote
Old 03-21-2011, 11:41 PM   #3 (permalink)
I will check all that. Besides that, in the meantime the head gasket got blown. so I will have some fun soon! thanks for ideas!
Old 03-22-2011, 05:46 AM   #4 (permalink)
Once you get the cylinder head make sure you bring it to a machine shop and get it pressure tested and checked for cracks, there is nothing worse than putting a head gasket on and finding out that the head is warped or cracked.......trust me.
Old 04-06-2011, 11:27 PM   #5 (permalink)
WABMWTECH is on a distinguished road
When you do that head job just pray the threads don't come out of the block
WABMWTECH is offline   Reply With Quote
Old 04-06-2011, 11:29 PM   #6 (permalink)
Never use the old bolts, always get new ones.
Calling all fuel trim experts!! kazamali 3-Series (E36) 2 08-17-2010 06:45 PM
P0340 P1188 P1189 besian vanos seals indianolajohn 5-Series (E12,E28, E34, E39, E60) 3 03-29-2010 12:27 PM
'01 540i fuel trim problems RockyBalboa-UK 5-Series (E12,E28, E34, E39, E60) 7 12-17-2008 11:09 AM
Fuel Trim Additve Banks 1 & 2 Low dedahed 5-Series (E12,E28, E34, E39, E60) 9 09-23-2005 04:40 PM
Fuel Trim Malfunction daves7x20 1,6,7,8 - Series and Mini Cooper 4 01-14-2005 04:10 PM
