Hi all, looking for some advice on my 1999 318i
(one with the nearly 2l engine)
1st - I seem to be lacking power. On my drive to work i avg 31MPG which is fairly good? but i seem to be low on the power?
I had a 1995 E36 1.8 and it seemed so much more lively than this heavy bugger! Some peep have said its heavier and got more equip, but i cant believe its this under powered.........
Iv changed the CCV and broken vacuum tube, That really helped giving more pulling away power...
My DISA valve makes a rattle, but from what i've read this doesn’t affect the power too much???? IS this true?
And i unplugged my Cam sensor, and noticed no difference to the running???? Nor did any warning lights come up! Is the correct??? What should happen when the cam sensor is unplugged?
Bit confused with this one, and advice or info would be great
