E46 318 Ci Rattle... - BMW Forum - BimmerWerkz.com
Old 01-16-2005, 07:59 AM   #1 (permalink)
storme's Avatar
storme is an unknown quantity at this point
1st of all hello to everyone,i am a frequent viewing but 1st time poster
i have a yr 2000 318 ci
it needs your help!!!!
in the morning after a long night in the garage,,when i start the car,,it sounds like the 4 cylinder 318 i that it should be,,sounds just dandy
but
after the oil has heated a bit,it gets a bit rattly..
if i turn off the car and wait 10,20,30 40 minutes etc,,,,,when i re start it,,it rattles like a diesel...all from the top end,,,,but not like a click,,like an injector
it rattles like the hydraulic tappets....
if i allow the car to cool for a few hrs,,when i re start it,,it sounds ok again..
i have re placed the oil 4 times in the 3 mnths since i bought it...
i have put in 0w 30..5w 30...15w 50[to try a thick oil]
and have now put back in 5w30...all being castrol or mobil synthetic oil
by replacing the oil,it all sounds ok for a few hrs,,but then it is back to normal
a rattle on start up...
the car itself goes like a dream looks like a dream
what should i do???
get new hydraulic lifters?? or do i need a whole rebuild? the cam sounds ok,,,the is no constant ticking sound when driving ,,,just a tappety sound at low tick over,,when i drive it,,it has all but gone,,maybe a small ticking,,only to my ears
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Old 01-16-2005, 01:53 PM   #2 (permalink)
ticking sound is usually lifters, and you can drive for a long time before this develops into a problem.
i am not sure if the m40 motor has a hydraulic timing tensioner: if it does this may be at fault, and requires replacement asap.
i woudl not put 15w oil in it, too dense especially in winter.
Old 01-16-2005, 02:30 PM   #3 (permalink)
storme's Avatar
hi
i have taken out the thicker oil,,and put the 5w30 back in..it was only a trial to see if it made any difference,,which it didnt
it is also an m43 engine...does this have a hydraulic timing tensioner??
also ,,when the engine is warm,,it ticks a bit,,but only on idle,,not while driving
Old 01-16-2005, 04:13 PM   #4 (permalink)
this is almost certainly lifters. i think you just don't hear the tick over the engine racket at revs....
tensioner, anyone?
E46 Aerial help ? Ramon Di Carrera 3-Series (E46, E90) 3 11-12-2005 09:44 AM
Help with E46 aerial connection ? Ramon Di Carrera Audio and Electronics 0 11-03-2005 12:02 PM
e46 330xi vs e46 325i Hot Sauce Driving Tales 3 10-26-2005 08:42 AM
05 325i Trunk Rattle Noise sudoloop 3-Series (E46, E90) 6 03-14-2005 03:47 PM
Rear Brake Rattle on 323 Conv. silvox 3-Series (E36) 4 07-07-2004 01:20 AM
