E46 2003 330i Harman Wiring Diagram Needed - BMW Forum - BimmerWerkz.com
Old 04-01-2010, 02:29 PM   #1 (permalink)
Twistapro is on a distinguished road
Hi, I'm trying to connect an aftermarket Alpine IVA D106 to my HK 10 speaker system. Can anyone help me with the wiring harness diagram...please. i have no clue whats going on at the back of my factory system.
Twistapro is offline   Reply With Quote
Old 04-04-2010, 12:13 PM   #2 (permalink)
Car: stock 2000 323Ci aftermarket stereo
outriggen is on a distinguished road
output to amp:
Radio Constant 12V+ Wire: Red/White
Radio Switched 12V+ Wire: Purple/White
Radio Ground Wire: Brown
Radio Illumination Wire: None
Radio Dimmer Wire: None
Radio Antenna Trigger Wire: White
Radio Amp Trigger Wire: None
Front Speakers Size: 5 1/4″
Front Speakers Location: Kick Panels
Left Front Speaker Wire (+): Yellow/Red
Left Front Speaker Wire (-): Brown/Orange
Right Front Speaker Wire (+): Black/Red
Right Front Speaker Wire (-): Brown/Orange
Rear Speakers Size: 4″
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Yellow/Black
Left Rear Speaker Wire (-): Black/Orange
Right Rear Speaker Wire (+): Blue/Black
Right Rear Speaker Wire (-): Brown/Orange
output from amp to speakers:
Woofer connection
pin # Wire color Description
23 blue/red (+) front right
22 blue/brown (-) front right
25 blue (+) rear right
24 brown (-) rear right
2 yellow (+) rear left
1 brown (-) rear left
4 blue/white (+) front left
3 blue/brown (-) front left
Tweeter Connection
33 yellow/red (+) front left
34 yellow/brown (-) front left (mine is yellow)
31 yellow/black (+) rear left
32 yellow/brown (-) rear left
13 yellow (?) rear right
21 blue/yellow (?) rear right
11 blue/black (+) front right
12 blue/brown (-) front right
Midrange Connection
pin # Wire Color Description
41 blue/green (?) front right
42 green (?) front right
39 blue/white (?) front left (pos?)
40 white (?) front left (white/brown -)
outriggen is offline   Reply With Quote
Old 04-04-2010, 03:51 PM   #3 (permalink)
Thank You. This really helps. Sorry if I sound really silly. I'm kinda new to this radio thing.
My factory radio (BMW Professional, I assume) was stolen before I bought this vehicle. It currently has a ten speaker Harman Kardon system connected.
Does all the speakers get its current feed from the amp. I ask cos, I need to connect my new Alpine in. Do I just connect the line out feed to the amp and will all the speakers start playing or just some of it
I have three speakers on each front door, one on each rear door and two enclosed boxes on the rear panel (Below the rear windscreen). Does all get it feed from the AMP. or does some get feed from the deck itself.
What wire can I connect to send feed (line out) to the amp. I have RCA out from my Alpine. How do I connect this to the amp.
I know you might think I'm nuts at this point but please help.
Thanks Clive
Old 04-04-2010, 04:06 PM   #4 (permalink)
ah I dont think your nuts but you have your work cut out for you. I had similar problem when I bought my car but I choose to replace the amps and all. I used the factory wiring only to bring the signal from my new amp to the speakers. You can try to go from the new deck to the factory input wires to the amp.(I would buy a wiring harness from ebay)
Old 04-04-2010, 04:09 PM   #5 (permalink)
also you may want to check this out
WDS BMW Wiring Diagram System - Model Selection
Old 04-04-2010, 04:12 PM   #6 (permalink)
What Harness would I be lookin for?
Old 04-04-2010, 04:21 PM   #7 (permalink)
02 03 04 05 BMW 330 WIRE HARNESS CAR RADIO WIRING 1010 : eBay Motors (item 220570772876 end time Apr-11-10 08:40:43 PDT)
Old 04-04-2010, 04:48 PM   #8 (permalink)
Checked out the link. Will I still need the factory harness if I'm fitting an Alpine radio. I have the factory harness in the dash in front. just the plug has been cut off, wires stil there. Could I not connect the Alpine wires directly to the remaining cables in the Dash
Old 04-04-2010, 04:54 PM   #9 (permalink)
ya I missed that part, sorry. look through that link that I posted for the correct wire codes.
Old 04-04-2010, 05:11 PM   #10 (permalink)
Thanks, just one last thing. Which wire should I use to connect the line out from the Alpine to the AMP.
Old 04-04-2010, 05:32 PM   #11 (permalink)
line out from the alpine being the speaker out or the remote turn on for the amp?
if you are referring to speaker out I would just use the high level output from the deck. if you dont have speaker level outputs you are goin to need to put an aftermarket amp in.
if you are referring to power use remote out blue wire on deck.
Old 04-08-2010, 02:33 PM   #12 (permalink)
bainsforlife is on a distinguished road
went on this site and for some reason i cant open up the pages???
bainsforlife is offline   Reply With Quote
Old 04-08-2010, 05:07 PM   #13 (permalink)
They have some annoying format issue.
Old 04-09-2010, 01:40 AM   #14 (permalink)
I agree, have tried on numerous occassions.
need help wiring diagram millertimefl 5-Series (E12,E28, E34, E39, E60) 3 11-20-2011 07:25 AM
e46 wiring diagram El Presidente Audio and Electronics 11 04-18-2011 09:30 AM
wiring diagram Kowalski 3-Series (E21, E30) 2 10-24-2005 01:29 AM
2003 E46 330I OEM Hood thread OEM Parts 1 09-19-2005 07:07 PM
WIRING DIAGRAM NEEDED PHYUKEWE Bimmer Talk/Motorsports Talk 0 04-15-2004 02:59 AM
