Dumb Questions from a Newbie - BMW Forum - BimmerWerkz.com
Old 01-24-2004, 11:03 AM   #1 (permalink)
nit78 is an unknown quantity at this point
I know, I know I am almost embarassed to ask this but I am the second owner and I did not get a manual when I purchased the car. Where is the fuse box located? My lighter won't work and I am assuming it is the fuse.
Also when I turn the car off the oil light stays on in yellow instead of red any suggestions what this could be.
One final question: I want to set my time but I can't get my instrument cluster to switch to time instead it just switches back and forth between degrees celius and faranheit.
nit78 is offline   Reply With Quote
Old 01-24-2004, 02:50 PM   #2 (permalink)
chris323i is an unknown quantity at this point
I can answer the time question. Change your instrument cluster display to time with the button on the end of the stick on the LH side of your steering column. Then use the LH side trip odometer reset button to change the time.
Hope that works!
chris323i is offline   Reply With Quote
Old 01-24-2004, 03:36 PM   #3 (permalink)
TECH's Avatar
Hope that works!
Change the time with the RIGHT side trip button. Twist it one way or the other to change the time.
The fuse box is located in the glovebox. Look at the top, you'll see a couple of tabs, twist them and the fuses drop down. There should be a puller and a paper chart in there to tell you what's what.
The yellow oil light indicates that the oil level is low. Red is oil pressure.
Old 01-25-2004, 12:14 AM   #4 (permalink)
AZ325Ci is on a distinguished road
i agree with TECH.
AZ325Ci is offline   Reply With Quote
Old 01-25-2004, 04:04 PM   #5 (permalink)
Originally posted by TECH+Jan 24 2004, 05:16 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (TECH @ Jan 24 2004, 05:16 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-chris323i@Jan 24 2004, 04:30 PM
Hope that works!
The yellow oil light indicates that the oil level is low. Red is oil pressure. [/b][/quote]
Thanks for the correction TECH
Old 01-25-2004, 08:55 PM   #6 (permalink)
TECH's Avatar
Soytinely! :P
Newbie question(s) on engine maintenance Morgenster 3-Series (E21, E30) 9 12-19-2005 08:32 AM
Sorry for being a newbie, 523i se questions Byron320i 5-Series (E12,E28, E34, E39, E60) 3 09-14-2005 07:28 PM
Newbie questions on shifting crisdoc 3-Series (E46, E90) 2 01-28-2004 11:46 AM
Newbie questions Rayzorman1 Bimmer Talk/Motorsports Talk 17 11-27-2003 12:21 PM
Couple questions from a newbie playtothebeat 5-Series (E12,E28, E34, E39, E60) 1 09-15-2003 09:20 AM
