DSC problems - BMW Forum - BimmerWerkz.com
Old 10-18-2008, 06:29 AM   #1 (permalink)
hbbodley is on a distinguished road
DSC problems
With the DSC on the left front brake will grab real hard within the first 1/2 mile of driving then the system will turn itself off. When I cycle the key it will reset to on but the problem comes back. Any ideas what might be going on?
hbbodley is offline   Reply With Quote
Old 10-18-2008, 01:43 PM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Sticky caliper on the left front wheel.
Old 10-18-2008, 01:46 PM   #3 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
Any dsc lights?
Could be your ABS/DSC controller going bad....
1992 318i Coupe parts car
I am Captain Obvious
Old 10-19-2008, 07:33 AM   #4 (permalink)
After it happens the DSC light stays on which indicates the system has shut itself off. As far as a bad caliper there is no problem with the DSC off. Also when it happens you can hear a growling from under the hood which I assume is the ABS motor. Seems to happen when I make a left turn. Once i was turning left at an intersection and once when I was coming back onto the road after pulling onto the shoulder.
Old 10-19-2008, 08:00 AM   #5 (permalink)
marti5's Avatar
It sounds like the ABS unit is playing up, diagnostics will pick this up if it is, but from what youve said "Growling" I would say the unit is on its way out, I pressume you have checked the fluid level ?, If thats ok def the unit.
Old 10-19-2008, 02:00 PM   #6 (permalink)
Yep have to codes read! should tell you the issue what if you Manually turn the dsc off via the dsc button?
Old 10-21-2008, 07:45 PM   #7 (permalink)
no problems if you turn it off. happened to me twice in 30 min. I turned it off for 2 days and have since been driving with it back on and have had no problems so far. I want to buy a code reader are the ones made by peake good for a diy'er.
2006 M5 Please Help Dsc Malfunction Or K40/blinder Causing Problems? DREWK M-Series (M1, M3, M5, M6) 13 07-01-2006 01:50 PM
Brake system/DSC problems. Anyone experienced this? Long warning! stremboli 3-Series (E46, E90) 2 04-10-2006 05:49 PM
Dsc Vs Tsc blue04 3-Series (E46, E90) 3 11-26-2004 02:14 PM
dsc?? wuballz 3-Series (E46, E90) 3 05-15-2004 10:15 PM
DSC kkevin77 3-Series (E46, E90) 2 12-09-2003 08:12 AM
