Dsc & Abs Dash Lights On - BMW Forum - BimmerWerkz.com
Old 11-08-2004, 12:45 PM   #1 (permalink)
zjz4476 is an unknown quantity at this point
Hello,
I am new to this forum, so my apologies if I am not following proper protocol in asking some questions. I have a 2000 E46 323i and both of my DSC and ABS dash lights have come on and as to be expected both my ABS and traction control are no longer working. It is my understanding that it may be the ABS speed sensor. If so, what wheel would I find it on? I understand that all four wheels have speed sensors on them. If this does not sound like a speed sensor can anyone provide some potential fixes.
I don’t know if this would have caused the problem, but I put on new set of 18" BMW M3 performance package wheels on the car a year ago with no problems until now. Just a thought.
Please provide any insight you may have as I would like to fix the problem my self before spending the Big Bucks at the dealer.
Thank you
Zane Zwerenz
zjz4476 is offline   Reply With Quote
Old 11-09-2004, 05:49 AM   #2 (permalink)
Trigati is an unknown quantity at this point
I wish I could help you...I've just finished 1 month of hell trying to get my DSC fixed under warranty....probably not related but they found mine to be a wire grounding out occasionally causing the DSC computer to fail.
When they started to check they first re-calibrated and then replaced the steering sensor. They then checked the logs on the wheel sensors to ensure they were working...finally they replaced the traction control computer itself. I believe this part cost about £1000 (UK pounds). They were about to move onto to replacing the Yaw sensor computer when they found the bad wire...30mmm of tape later and it's fixed.
All in all good luck...I wish you the best for this...
Mine's a Guiness.....
Trigati is offline   Reply With Quote
Old 11-09-2004, 03:46 PM   #3 (permalink)
vargonen's Avatar
vargonen is an unknown quantity at this point
Trigati,
What kind of problems did you had when it is not working, also did u ask them do they have to make you wait 4 one month until they find the wire?
Ali.
[snapback]227322[/snapback]
vargonen is offline   Reply With Quote
Old 11-10-2004, 11:08 AM   #4 (permalink)
The problems faced when it wasn't working was just no traction control or ABS...so wheelspin and locking brakes on loose surfaces.
I travel for work and could only let them have the car every other day rather than for a continuous period. They would change a part or configure something, test drive it, it would not fail so they'd give it back...It would then fail for me. They said they had to follow the factory support technicians advise on what to change and when so the costs where covered by warranty.
The only reason they finally discovered the wire was they loaned me a good car for one week. During that week they sent out their sales staff in the car each night. On the last day of the week the salesman who drove the car was rather large and the system failed everytime he moved in his seat, braked or cornered hard. At that point they stripped out the seat to check the electrics and disciovered this wire on the loom along transmission tunnel?
See http://www.bmw-forums.com/forum/inde...howtopic=23633
Old 11-10-2004, 03:33 PM   #5 (permalink)
2001BMW330iRob is an unknown quantity at this point
I had the same lights on one day off the next!
I changed the brake fluid and all is well now!
Not sure if that helps!
I did it myself, no stealership intervention!
2001BMW330iRob is offline   Reply With Quote
Old 11-11-2004, 09:46 AM   #6 (permalink)
Thank you for all of your feedback. My lights went on one day off the next, for about a week. Now they are on all the time. When you changed your brake fluid, did you do a complete flush? If so is there a write up on how to do this properly?
Thanks
Zane
Old 11-11-2004, 08:15 PM   #7 (permalink)
E36KindaGuy's Avatar
E36KindaGuy is an unknown quantity at this point
I am not 100% sure about this but I believe you need to recalibrate your system computer after putting on rims large then 17s.
E36KindaGuy is offline   Reply With Quote
Old 11-12-2004, 12:45 AM   #8 (permalink)
BMWLotAttendant's Avatar
BMWLotAttendant is an unknown quantity at this point
Send a message via AIM to BMWLotAttendant Send a message via MSN to BMWLotAttendant
Sounds like bad news....when the DSC is off...you could seriuosly screw up your car worse than you think....better head off to the dealership...
BMWLotAttendant is offline   Reply With Quote
Old 11-14-2004, 05:01 PM   #9 (permalink)
Thanks
Zane
[snapback]228632[/snapback]
http://www.trackhaus.com/category-exec/category_id/7
I bought my brake bleeder from trackhaus!
Great investment, I changed my brake fluid on both my 318i and 330i!
They give good directions, however if you are not mechanically inclined take it to a shop and get it done.
Brake fluid should be changed once every two years!
With the brake bleeder it is easy and actually fun to do!
There are some tricks to doing the job right!
Good luck.
Old 11-20-2004, 12:56 AM   #10 (permalink)
boaz is an unknown quantity at this point
Originally posted by zjz4476@Nov 8 2004, 12:45 PM
Hello,
Thank you
Zane Zwerenz
[snapback]226844[/snapback]
boaz is offline   Reply With Quote
HELP - Brake, ABS, and DSC lights on Fangs 3-Series (E46, E90) 48 05-13-2011 01:39 PM
Questions About Dash Lights? Sasha 3-Series (E46, E90) 2 03-25-2005 04:05 PM
Dash Lights metalmayhem 3-Series (E36) 5 12-27-2004 09:53 AM
Dash Lights metalmayhem 3-Series (E36) 0 12-25-2004 04:35 AM
Dash lights out on MZ3.... NitroRoadster 1,6,7,8 - Series and Mini Cooper 2 10-16-2003 09:09 PM
