do your brakes squeak? - BMW Forum - BimmerWerkz.com
Old 09-13-2004, 02:09 PM   #1 (permalink)
GnarlyCow is an unknown quantity at this point
Arrow
Hello again.
My brakes are squeaking like an old garbage truck and it's really embarrassing. It's hard to look cool while coming to the stop when all the women are cringing from the loud shreak of my brakes.
I asked the dealer about this and he said that it's common for these brakes to squeak. Somehow I doubt this. They said that I should just do a few hard braking maneuvers and that after I do a few of those, my brakes should be fine.
Is this happening to everyone else? I've never had brakes before that were this squeaky before.
GnarlyCow is offline   Reply With Quote
Old 09-13-2004, 02:28 PM   #2 (permalink)
skawful's Avatar
skawful is an unknown quantity at this point
Send a message via AIM to skawful
only during the summer and when my brakes are REALLY hot
<img src='http://img259.imageshack.us/my.php?image=sig8hw.jpg' border='0' alt='user posted image' />
skawful is offline   Reply With Quote
Old 09-14-2004, 07:22 AM   #3 (permalink)
trojp's Avatar
trojp is an unknown quantity at this point
Are the brakes original BMW brakes?
My dad had a mercedes 190E, he decided to fit non orginal brakes and they startedto squeak hard, very embarssing, also are they aligned properly?
trojp is offline   Reply With Quote
Old 09-14-2004, 08:24 AM   #4 (permalink)
squeak is good. but, if you are concerned about females:
usually the squeak comnes form the vibration of the pad against rotor surface (that is if you have stock brakes). you can almost always solve this by applying an adhesive to the back of the pad. any competent shop can do this.
Old 09-14-2004, 09:02 PM   #5 (permalink)
These are original brakes....at least I have never changed them. I bought this car as a certified series 2001 325Ci from the dealership about 4 months ago. They just started squeaking about 3 weeks ago or so and now squeak everytime I hit the brakes (light braking). Perhaps I will just start binary driving: either full gas or full brake At least that way I won't get squeaky brakes....just a few tickets :P
Old 09-14-2004, 11:26 PM   #6 (permalink)
nx07 is an unknown quantity at this point
You might just require new pads probablly, not sure though, maybe even a C-Clamp could do the trick? Not sure though, it all varies on the problem at hand.
If you can, I would get a second revision done by another dealer if troubleshooting doesn't work out'
Good luck man!
nx07 is offline   Reply With Quote
Old 09-14-2004, 11:38 PM   #7 (permalink)
ACSTypeI is an unknown quantity at this point
Squeeking can also be caused by crystallization on the brake bads. This happens when the brakes are heated to a really high temperature and cool too fast. Typically this happens to people who brake slowly and over long distances. (e.g. grannies that start braking for a stoplight 2 blocks away) The friction builds up tremendous heat.
If that's the problem, then the dealer's solution was correct. speed up and brake hard a couple times. Ideally, you want to brake late and hard all the time, but it's not practical for street driving.
ACSTypeI is offline   Reply With Quote
Old 09-16-2004, 06:35 AM   #8 (permalink)
so true about the glaze, but please....
Old 09-16-2004, 12:55 PM   #9 (permalink)
Threadkiller
bitcore's Avatar
What a way to wear out the pads...
Is this true by any means?
I've never had any glazing problems and I drive like a freaking maniac, stock rotors and equipment. I dont know what pads I have on this time, someone else did them.
Old 09-20-2004, 03:44 AM   #10 (permalink)
BMWLotAttendant's Avatar
BMWLotAttendant is an unknown quantity at this point
Send a message via AIM to BMWLotAttendant Send a message via MSN to BMWLotAttendant
Yeah I notice that alot too when I'm driving new/customers vehicles. It is normal for them to do that. I don't know why....but that's the way they were made.
BMWLotAttendant is offline   Reply With Quote
Old 09-20-2004, 05:51 AM   #11 (permalink)
/Banned
HamannM3's Avatar
HamannM3 is an unknown quantity at this point
at one point my brake pad sensor failed. i was down to the metal before i realized that the computer was wack and i needed to check for myself.
HamannM3 is offline   Reply With Quote
Old 09-22-2004, 07:52 AM   #12 (permalink)
teoh is an unknown quantity at this point
To stop squeaking, try look for a mechanic to machine your discs, and if necessary change the brake pads.
teoh is offline   Reply With Quote
Old 09-22-2004, 08:03 PM   #13 (permalink)
[snapback]196634[/snapback]
Shouldn't this have been done as part of the BMW certification process my car 'apparently' went through? I guess they didn't do it so I would have to pay for the service coming up in 10000km more.
Had To Replace Brakes At 15,000 Miles Now At 25,00 eburatti 3-Series (E46, E90) 15 10-25-2005 10:36 AM
Squeky Brakes ynotony 3-Series (E36) 2 07-21-2005 06:07 PM
Squeeling New Brakes Ljk619 3-Series (E46, E90) 6 07-08-2005 01:31 PM
2001 330i Brakes? zach 3-Series (E46, E90) 2 12-09-2004 05:42 PM
Steering Shaking With And Without Hot Brakes zanick 3-Series (E46, E90) 3 10-26-2004 11:02 AM
